Results 1 to 11 of 11
    bricioborges's Avatar
    bricioborges Guest
    Smile Change R417a to R22
    I have a unit air conditioner 16000 btus. the gas used is R417a, but i do not have this gas, i have R22.
    Can i used R22 in this compressor.
    Jul 2008
    taguig city
    36
    Re: Change R417a to R22
    bricioborges,
    just stick to the original refrigerant.
    regards
    11,025
    R417a is a direct replacement for R22 so yes you should be able to use R22, check that the oil is compatible.
    Remember that R22 is being phased out in some parts of the world
    Mar 2006
    Merate (LC) - Italy
    2,549
    That doesn't mean that you can fill it up with R22. Generally R417a is used as a replacement for R22, not the other way around.
    Dec 2008
    564
    If the system has been designed for R417a, then I wiould suggest that you buy the correct grade of refrigerant as the system may have been optimised to suit R417a. You could invalidate any warranty by using the wrong grade of refrigerant.
    bricioborges Guest
    I would like use the correct gás, but i work in plataform of oil (offshore), and dont have r417a. i just to buy, but now i need the equipament start, and i have only R134, R22 and R410.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Buy the correct refrigerant. Full stop.
    Oct 2007
    NZ
    85
    Quote Originally Posted by NoNickName View Post
    maybe so , but we have taken 404a units in the past with poe oil and changed the valve and converted to r22, so as long as 417a is a drop in for r22 the valve if fitted should be quite close , it may just be a case of putting r22 in and giving it a go adjusting the s/heat , I certainly would and just carefully monitor it for a day or 2 after all hes on an oil platform and wont be going anywhere and being on an oil platform the enviroment would hardly be an issue.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Why were you asking in the first stage, then? You are already convinced, then go ahead.
    Jul 2008
    Singapore
    11
    Hi!
    R417A is developed by Rhodia and now sold to DuPont. It's easy available in Asia e.g S'pore n Malaysia. If u r in Marine sector, u may contact Unitor Ship supply etc.
    Rgds,
    Koh - Singapore
    65-98176373
    Jul 2008
    Singapore
    11
    Hi! R417A is market by DuPont also known as Isceon MO-59. This product should be available if u contact their distributor or otherwise, u should be able to source it fm Unitor ship service since u mentioned it is meant for oil-rigger.
    We have stock for R417A but unfortunately we are based in S'pore.
    As suggested by most of our members, I agree u should not put R22 back into this system as by law especially in EU, all equipment must be zero ODS.
    Have a good day!
    Koh - S'pore
  1. R 417 A direct replacement of R 22
    By abbasi in forum Refrigerants
    Last Post: 08-09-2011, 12:47 AM
  2. How do you change oil on rotary?
    By Raadster in forum Fundamentals
    Last Post: 28-07-2008, 06:05 PM
  3. nitrogen presure/ tempurature change.
    By neil74 in forum Fundamentals
    Last Post: 06-03-2008, 10:25 PM
  4. Freus, water cooled, change gas?
    By Dennis Williams in forum Air Conditioning
    Last Post: 27-06-2007, 07:04 PM
  5. R417a
    By Lc_shi in forum Refrigerants
    Last Post: 15-11-2006, 07:35 PM
