Thread: danfoss txv insulation
02-12-2008, 07:46 AM #1
hi everyone.I am looking for a plastic cover(2 pieces) desighed for txv when it's installed outside of a cold room to avoid condesation.can anyone help me find these? thanks
02-12-2008, 12:08 PM #2
Re: danfoss txv insulation
What about the black bitumastic and cork insulation that can be moulded by hand.
I think its made by Virginia/KMP....possibly called presstite?
02-12-2008, 02:59 PM #3
i know this tape you are talking about but if you'd seen this plastics you ll understand it's the perfect solution.Also it is easy for the technician to install and uninstall them because they are fasten together with plastic strips.Thank you anyway
02-12-2008, 08:06 PM #4
Get a sheet of that blue building insulation, or polystyrene and cut into two blocks, hollow it out and sandwich the tev in the middle.
03-12-2008, 11:23 AM #5
Hi Lazaros,
Since your from greece, I think it would be possible to find these in Italy. For ex.:
http://www.frizzi.it/index.php?pg=na...t=911&pro=5833
03-12-2008, 01:32 PM #6
thank you very much for the information it was very usefull !
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
By lazaros in forum Trouble ShootingReplies: 1Last Post: 29-11-2008, 01:58 PM -
Help needed sourcing insulation for a Display Case
By jimbo22 in forum Technical SpeculationsReplies: 2Last Post: 03-11-2008, 09:30 AM -
Problems Danfoss Safetyvalve
By Bart Nabbe in forum NH3Replies: 7Last Post: 26-06-2008, 09:05 PM -
Emmisivity as insulation thickness determinant ?
By sharshal in forum Technical SpeculationsReplies: 4Last Post: 23-10-2006, 02:26 AM
