    Feb 2008
    Lima - Peru
    41
    49
    intercooler with coil
    HI everybody:
    I need to size the pipe of the Intercooler ( i attach draw) i can't size the pipe of ''liquid in to subcooling coil'' and ''liquid inlet from hpr'' somebody can help me.
    Luis Sandoval.
    Attached Files Attached Files
    Aug 2005
    5,302
    Re: intercooler with coil
    Hi Luis,
    The vessel manufacturer will normally provide a pipe size for their standard vessels. I guess I am wondering why you would want to size this pipe.
    If the pipe size is too big the subcooling coil may be smaller also.
    Nov 2008
    alaska
    58
    11
    Luis:
    Try going to evapco.com, click on product info, then asme pressure vessels, open the mvi intercooler page and print it. There is a a lot of sizing and tonnage data in their charts. Their engineers have done the work already so why beat your head against a wall redesigning a wheel. As a bonus you might find purchasing one premade is cost effective
    Dan
    Mar 2009
    1
    Post Good post
    Good post! I plan to move into this stuff after I’m done with school, as most of it is time consuming. It’s a great post to reference back to. My blog needs more time to gain in popularity anyway.
    Sep 2006
    Venezuela
    259
    luissandoval
    Q=U * A*Delta T log
    Q= m*cp (Ti-To)= ammonia flow in pipe * Cp* Subcooling range
    U= Look in Ashrae "Fundamental" for ammonia bubble tipe heat transfer and find this Number according your conditions
    Delta T log= Mean T log Difference
    Now you can figure A =area
    As you know the pipe diameter, now you will be able to find the pipe lenght
    Remenber the pipe should be bend so you need two or more tubes installed in paralle
    Hope this can help
  1. heating coil or cooling coil?
    By botching in forum Air Conditioning
    Last Post: 09-06-2008, 08:37 PM
  2. Efficiency of compressor assisted HRV
    By montreal in forum Heat Pumps
    Last Post: 27-08-2007, 08:51 PM
  3. Dont be shy, advice needed.
    By Sledge in forum Air Conditioning
    Last Post: 27-06-2007, 03:09 PM
  4. Burst Coil
    By frank in forum Air Conditioning
    Last Post: 20-02-2005, 06:28 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
