    Var's Avatar
    Var Guest
    Fridge making high pitched noise
    Hi folks,
    I've been given a standard kitchen refrigerator that when I turned it on made a high-pitch "ooo" sound for many hours.
    The last time I heard such a sound it was from a car's air conditioning system and I think it indicated a leak.
    This fridge was made in 1997. It does smell quite bad, sort of a plasticky smell.
    Any ideas as to what the problem might be?
    Thanks.
    Split Croatia
    6,175
    Re: Fridge making high pitched noise
    Could be capacitor!
    aaronb's Avatar
    aaronb Guest
    Its likely to be a capilary system and these make noise as the gas passes the tiny pipe and also for a short while after its down to temp. I doubt it has a compacitor. the gas would still leak if it was off.
    May 2008
    66
    802
    if the fridge was on his side for a wile,you have to let it straight up for 12 hours before you switch it one again.
    also take a look ad the compressor, is it a 50 ore 60Mhz and what is your's ??
    Ice
  1. Making a vacuum pump from a fridge compressor
    By splott in forum Refrigerants
    Last Post: 02-09-2008, 07:46 AM
  2. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  3. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  4. Old fridge not cooling but making funny noise
    By TygerTung in forum Domestic
    Last Post: 27-03-2008, 01:26 AM
  5. whirlpool fridge not working rattling noise
    By pops1 in forum Domestic
    Last Post: 17-02-2008, 07:52 PM
Tags for this Thread
