Thread: Pressure Test Levels
29-11-2008, 04:58 AM #1
Hi friends...one question is bothering me from a very long time...CAN WE CHARGE OUR REFRIGERATION SYSTEM (compressor, condenser, Evaporator and refrigerant control device: i mean complete system) with 400psg. N2 or dry air pressure for leak testing purpose is this is advisable or not ??
29-11-2008, 09:13 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: beginer questions
For split system air conditioning (found on Mitsubishi HI manual):
Required pressure for testing air tightness in connecting pipes and indoor units of split system air conditioners prior to opening service valves and evacuation is:
R22 = 2.94MPa = 368PSIG
R407C = 3.23MPa = 468PSIG
R410A = 4.15MPa = 602PSIG
For outdoor unit, maximum pressure could depend on installed elements max pressures indicated at each element (compressor and etc...).
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
