Thread: Recovery tank
    May 2008
    us of a
    90
    8
    Talking Recovery tank
    hey guys! been a few months since last i surfed this site! I reinsulated and re-sided my daughters family home this summer ... latest addition of hers is 2 year old "Angel" .. an now we have a week old great grandaughter too! been quite a year!!
    I have a Thermo-flo recovery unit but no tank, and am planning to convert a 30 lb propane tank to do the task .. i would remove the valve and put a tee on the tank so that a modified valve that has a copper line added, would reach the bottom of the tank through the tee, and a second valve would access the top of the tank ... the thermo-flo can recirculate the refrigerant to cool it so it requires a two valve tank ... any constructive thoughts wiil be gratefully accepted!! dddon ...in coool minne-soda, usa ....
    Split Croatia
    57
    6,151
    36
    Re: Recovery tank
    Check maximum pressures for that tank and install some safety relief valve if you dont have one, or else, you will end up with bomb.
    11,025
    Re: Recovery tank
    Why not get a proper refrigerant cylinder with the two valves and dip tube already fitted?
    Nov 2008
    spain
    59
    38
    Re: Recovery tank
    I have a quick question on this, I have just got a new recovery cylinder, on the top there is what i presumed was a pressure relief valve, but it has an electrical connection on the top of it, is this a pressure relief valve with a built in sensor? can somebody shed some light?
    Steve
    Sep 2005
    uk
    499
    21
    Re: Recovery tank
    Quote Originally Posted by steve_k View Post
    Steve
    Level switch, links to rec. mac. and stops when bottle is 80% full. connection is specific to manufacturer i would think,and not compatible with any kind of rec. mc.
    Takes a licking, keeps on ticking.
    May 2008
    us of a
    90
    8
    Thumbs up Re: Recovery tank
    Thanks for the comments!! I got a recovery tank today, and am sure that it is much better than a propane tank modified !! i grew up in an era of NO money, an built or coverted whatever i could find to do the job .. most of you would hardly believe the various projects that I worked on. If i could type faster than a word every few minutes , i would make a journal of my experiences ... thanks again!! dddon
  1. Calculation bypass buffer tank volume
    By abbasi in forum New Technologies
    Last Post: 16-10-2008, 06:19 AM
  2. Bypass buffer tank volume
    By abbasi in forum Technical Speculations
    Last Post: 15-10-2008, 05:28 AM
  3. How an expansion tank works?
    By Raadster in forum Fundamentals
    Last Post: 25-07-2008, 02:25 PM
  4. complete System Recovery
    By absolute-zero in forum Computers & the Internet
    Last Post: 20-01-2008, 06:03 PM
  5. recovery tank question
    By flyboy3b in forum Fundamentals
    Last Post: 05-12-2007, 03:25 PM
