Thread: issue ??
28-11-2008, 10:29 AM #1
issue ??
i work on cascade systems that use r170 (ethane) which is highly flamable is there a potential risk if there was a low side leak and the compressor went to earth ?
28-11-2008, 08:21 PM #2
Re: issue ??
The earth leak would be inside the compressor we assume and the leak would be outside of the system.
The chance of there being an explosive mixture within the system is extremely unlikely.Brian - Newton Abbot, Devon, UK
28-11-2008, 11:11 PM #3
Re: issue ??
thanks, thought it may be possible if low side was running in a vacuum
29-11-2008, 03:50 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
04-12-2008, 03:20 PM #5
Re: issue ??
so normal running pressure is about 3 to 5 psi, so if there was a leak on the suction side and no Lp cut out fitted then there would be a vacuum so oxygen would be introduced to the system if the compressor went to earth is it possible that there may be combustion ?
Flood back issue?
By Arc in forum Trouble ShootingReplies: 15Last Post: 28-10-2008, 03:40 PM -
electrical heating cable issue
By Lc_shi in forum New TechnologiesReplies: 2Last Post: 21-07-2007, 09:51 PM -
large refrigeration plant cooling tower issue
By Lc_shi in forum New TechnologiesReplies: 4Last Post: 25-03-2007, 01:35 PM -
hydraulic floor heating issue
By Lc_shi in forum New TechnologiesReplies: 6Last Post: 02-01-2007, 09:07 PM -
MIHI price issue
By madwoody in forum Air ConditioningReplies: 7Last Post: 04-11-2006, 12:43 PM
