Thread: issue ??
    Nov 2008
    issue ??
    i work on cascade systems that use r170 (ethane) which is highly flamable is there a potential risk if there was a low side leak and the compressor went to earth ?
    11,025
    Re: issue ??
    The earth leak would be inside the compressor we assume and the leak would be outside of the system.
    The chance of there being an explosive mixture within the system is extremely unlikely.
    Nov 2008
    Re: issue ??
    thanks, thought it may be possible if low side was running in a vacuum
    Split Croatia
    57
    6,151
    36
    Re: issue ??
    Quote Originally Posted by ozzy bill View Post
    Burning or combustion cannot take place if there is no oxygen!
    Nov 2008
    Re: issue ??
    so normal running pressure is about 3 to 5 psi, so if there was a leak on the suction side and no Lp cut out fitted then there would be a vacuum so oxygen would be introduced to the system if the compressor went to earth is it possible that there may be combustion ?
  1. Flood back issue?
    By Arc in forum Trouble Shooting
    Last Post: 28-10-2008, 03:40 PM
  2. electrical heating cable issue
    Last Post: 21-07-2007, 09:51 PM
  3. large refrigeration plant cooling tower issue
    Last Post: 25-03-2007, 01:35 PM
  4. hydraulic floor heating issue
    Last Post: 02-01-2007, 09:07 PM
  5. MIHI price issue
    By madwoody in forum Air Conditioning
    Last Post: 04-11-2006, 12:43 PM
