Results 1 to 2 of 2
Thread: Fridge Freezer over heating
27-11-2008, 12:40 PM #1
HI
I have an hotpoint fridge freezer FFA70 the fridge is working fine but the freezer has a light on it that says high freezer temp. this happend 2 days ago. I turned the freezer down and it went off. Today it has come on again. I have turned it down to number 2 but it is still on.
I can't find the manual sadly, so was hoping someone on here may know what I can do?
The bottom drawer has a small build up of ice. I wondered if the freezer sensor maybe blocked or something?
27-11-2008, 12:59 PM #2
Re: Fridge Freezer over heating
There are better people on here that may know about your specific fridge and I'm sure they will give you a more reasoned answer but you will not go wrong if you empty the thing and leave it off for 24hrs to defrost. Switch it back on when you are sure it is defrosted and dry. Let it run and see what happens.
Cheers taz.
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Insulation betweem separate Fridge and Freezer
By Jim30 in forum FundamentalsReplies: 7Last Post: 13-07-2008, 08:55 PM -
Help! fridge freezer probs
By Glenreed in forum Trouble ShootingReplies: 2Last Post: 06-01-2006, 10:51 PM
