Thread: Alcohol flush?
27-11-2008, 12:28 PM #1
Alcohol flush?
Hi Guys
Well trying to get a decent flushing agent to the Congo is not easy as I am told most from S Africa are "Hazmat" ie flammable and cant come by air
About the only thing I can get here is rubbing alcohol. I have used it slightly before on another condensor flush with a sort of success
I intend flushing out bad oil from a Ziagra icemachine plant[7.5hp Copeland semi] using a waterpump and then 8bar of air to blast stuff out then lots of vaccuming.
Any comments?
George
07-12-2008, 09:13 AM #2
Re: Alcohol flush?
first things first M8, alcohol is for drinking ore medical service. flushing material can be made from several things like the oil you intend to yous,and a filter. NEVER and i mean NEVER blow air in refrig lines. if you have the opportunity or access to dry air, but again its better to have nitrogen.
Ice
07-12-2008, 09:15 AM #3
Re: Alcohol flush?
ps; how are things over there ??
Ice
Alcohol in the jungle
By George Askew in forum Technical SpeculationsReplies: 1Last Post: 27-11-2008, 12:30 PM -
Flush the system
By Mohammed Qasim in forum Air ConditioningReplies: 3Last Post: 03-01-2007, 08:35 PM -
cleaning pipes with rubbing alcohol?
By star882 in forum FundamentalsReplies: 7Last Post: 29-09-2006, 07:40 PM -
Rubbing alcohol.. the horror
By Tycho in forum Chit Chat & Service StoriesReplies: 15Last Post: 29-09-2006, 01:49 PM -
rx11 flush
By tony_rich in forum New TechnologiesReplies: 0Last Post: 10-08-2003, 04:04 PM
