Results 1 to 8 of 8
Thread: Thermo King Alarm Code
26-11-2008, 05:38 PM #1
I have a 2000 Thermo King SBIII SR+ with an alarm code 50 (reset clock). I don't know how. Please help!!
27-11-2008, 05:48 AM #2
Re: Thermo King Alarm Code
Hold the TK logo key in until pretrip comes up on the display, press the select key until the year comes up, change the year with the up/down keys, press enter when correct, select to the next screen and repeat for date and time. Code 50 will self clear after the time is set.
29-11-2008, 03:35 AM #3
Thanks for the response. Worked great!!! I bought this trailer used and it didn't come with a manual.
19-09-2010, 10:51 AM #4
I HAVE A SBIII SLE SR WITH ALARM 111 I dont know how
19-09-2010, 10:59 AM #5
I have a sb3sle thermoking with code 111 and shutdown unit i dont know .pleas
19-09-2010, 10:20 PM #6
Not configured correctly, requires a trained tech to sort it out
20-01-2011, 06:42 PM #7
tengo un Termo king SBIII, con un codigo 75
21-01-2011, 07:27 AM #8
http://www.trailerservices.com/resou...larm_Codes.pdf
list of alarm codes for TK
75 is RAM failure, new one to me
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 24-01-2012, 12:23 AM -
please help! thermo king wiring
By micki_kp in forum TransportReplies: 3Last Post: 17-11-2008, 09:59 AM -
Thermo King Refrigerant Help!
By jingua_ph in forum TransportReplies: 43Last Post: 12-04-2008, 01:19 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 09:01 AM
. Does the person have to be local to you or could the work be done long distance using email and the web? Rob .
How to find Contract workers
