Results 1 to 9 of 9
    Oct 2008
    Iran
    40
    11
    Choosing correct electrical heater
    In case of using mixing box atached to single rooftop package unit , I want to use electrical heaters in case of heating in winter In which all the components stop except evaporator fan .... Calculated load is 36 KW , what size of electrical element I should use ? I mean the electrical consumption of heaters
    should I use 36 KW heater or less is sufficient ?
    thanks in advance
    Mar 2005
    u.a.e
    68
    169
    Re: Choosing correct electrical heater
    If you want to heat a comfort air system then you can calculate by formula,
    P= Q X 0.36 X (T2-T1)
    where
    P= heating power in watts
    Q= air flow m3/h
    T1=temperature in coming air *C
    T2=required temperature out going air *C
    Oct 2008
    Iran
    40
    11
    Thank you malik.
    but you didn't get my question
    as in your formula I calculated P as 36 KW
    I want to know which size of electrical heater I should by for producing 36KW heating capacity?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by mkardehi View Post
    Thank you malik.
    36 kW of electrical heater!
    That is his electrical power consumption AND his produced heating capacity.
    Oct 2008
    Iran
    40
    11
    Your answer is really shameful nike
    Jul 2008
    taguig city
    36
    mkardehi,
    do you mean diameter and length of electrical heater?
    REGARDS<
    Split Croatia
    57
    6,151
    36
    Why shameful? I answered your question! If you meant what dimension, it cannot be answered correctly, because it could be many dimensions and shapes for same power output.
    You got meaningful answer to your question.
    Rephrase your question in order to get answer which will satisfy your need.
    I am not mind reader, and I don't see any reason for you to be offended by my answer!
    Oct 2008
    Iran
    40
    11
    sry NIKE it was a problem of misunderstanding and difference in languages
    I am so sorry
    Thank you all , I got my answer
    Mar 2005
    u.a.e
    68
    169
    Good manners young man
  1. Single pole contactor & crankcase heater
    By herefishy in forum Air Conditioning
    Last Post: 01-04-2009, 08:38 AM
  2. Domestic electrical questions
    By Andy AC in forum Electrical
    Last Post: 02-04-2008, 07:39 PM
  3. Whirpool defrost heater
    By frozen fred in forum Domestic
    Last Post: 27-01-2008, 06:41 AM
  4. part p
    By eggs in forum Electrical
    Last Post: 15-11-2007, 08:55 PM
  5. VFD heat pump water heater?
    By star882 in forum New Technologies
    Last Post: 23-05-2006, 08:36 PM
