    Sep 2008
    Lancs - UK
    67
    30
    Exclamation Environmental Room
    I have been asked by one of our customers if it is possible to build a couple of small environmental rooms. These are to test the storage of aerosol canisters. They want to run the rooms at 40C and then bring back down to 20C. There will be two rooms approx 2.5 x 3.0 metres. Both require to run independently of each other. The problem that I have is I can’t find any equipment small enough to look after the rooms. Naturally small splits are out as they will not go upto 40C. Ducted systems are too large for these rooms and start at 5KW. I need something that is still what I would call basic control, not controlled by a microprocessor, preferably that can have electrical heaters fitted to them. Does anyone know of anything that is on general supply in the UK. I have tried the usual Airedale and IMI but they do not have anything to offer.
    11,024
    Re: Environmental Room
    Have you approached any AHU manufacturers about the problem?
    They should be able to come up with a simple solution for these rooms.
    Such as..
    http://www.nuaire.co.uk/Product/Comm...Handling_Units
    Aug 2005
    5,302
    Environmental chambers are very specialized. I have worked on a few for engine emission testing and large AC rooftop units. They are nothing like a split unit, etc.
    The refrigeration systems are either custom designed for the project by an enterprising company or provided by a manufacturer who does this type of work almost exclusively.
    Sep 2008
    Lancs - UK
    67
    30
    These rooms are not true environmental rooms as we know them, I have a number of large environmental chambers on contract. It is the small size of these rooms that is the problem, they are to enable the aerosols to be tested at 40C storage conditions. Finding equipment that as low as 2Kw on a ducted type is near impossible, and we dont have any hot water/steam near by either, so we are left with electrical heat again can't find anythig this low for close control equipment.
    Jan 2010
    Southern California
    I started my career working for Conviron, Controlled Environments Inc. They specialize in environmental chambers and growth chambers. This is a very specialized field.
    I can help you design the system you need.
    Drop me an email at c38refrigeration@yahoo.com
    Jeff P.
  1. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  2. Thawing Room (defrosting Room For Meat)
    By arunuae in forum Commercial
    Last Post: 09-02-2008, 09:24 AM
  3. Air conditioning for operating room
    By lana in forum Air Conditioning
    Last Post: 08-04-2007, 08:36 PM
  4. troubleshoot a two door storage room
    By duraid in forum Fundamentals
    Last Post: 13-12-2006, 06:57 AM
  5. Freezer Room Panels
    By Feeze in forum Technical Discussions
    Last Post: 22-04-2005, 05:58 AM
