    Nov 2008
    Peru
    11
    Unhappy Gravity liquid/vapor separator to little?
    Im from Peru, i have problems with liquid carryover to suction line compressors in ammonia system for an IQF tunnel, aeroheat model 2010, 2 Mycom N42WB, Gravity Liquid/vapor horizontal separator (2200 mm length x 600 mm dia).
    When start 2nd compressor, at 67% capacity, liquid carryover right to compressors. The contractor said the size of the separator is small, need to change for 3500 mm lenght x 1200 mm dia. because when we will load the tunnel could be worse.
    is that correct?
    thanks
    aphun
    Nov 2008
    Peru
    11
    Re: Gravity liquid/vapor separator to little?
    i forgot diagram
    Attached Files Attached Files
    Jul 2007
    Czech
    61
    374
    Hi Aphun,
    600 mm is really little, at least 1000 mm
    The high pressure liquid level makeup is suspect by your schematic also .
    It is close to dry suction, so higher velocities could cause carryover .
    Make sure regulating valve is adjusted so it is feeding liquid makeup 70 - 75 % of the time when at max load .
    Also make sure liquid reciever has good level so no hi pressure gas blasting into surge drum .
    Nov 2008
    Peru
    11
    Thanks Josef/Ranger1
    Here a contractor thinks if we place a liquid acumulator tank before suction compresors could we avoid that.
    But, that means increase the suction length in 10 mts (actual 18mts 5"dia) more, does it afect the suction temperature of the gas in order to get -35ºC in the tunnel?
    aphun
    Wont affect temps but you then also have to have heat source to boil off refrigerant that comes back to suction trap .
    ie liquid line coil inside suction trap also hi level cut out float control .
    Nov 2008
    Peru
    11
    Hi Ranger
    if the contractor wants to put inside this tank a heater like oil compressor with a level switch, in order to eliminate the liquid every time this turn on?
    thanks
    Nov 2008
    Peru
    11
    About the liquid carryover, its not the size of vessel; we raise the suction pipe over the level of the LVS, and remove the demister pad inside, instead put drop eliminator; and the problem is gone.
    aphun
    Aug 2005
    5,302
    Quote Originally Posted by aphun
    we raise the suction pipe over the level of the LVS, and remove the demister pad inside, instead put drop eliminator...
    A demister pad and droplet eliminator (I'm assuming you mean chevron style) both operate with similar velocities therefore, I would think the main issue could be assigned to the suction pipe being too close to the liquid level in the vessel.
    If that is the case, then you had insufficient separation distance to dis-engage the liquid form the vapor stream.
    Mar 2005
    638
    With out going in and doing a design calculation on your surge drum, I would first look at a few things.
    -Liquid level
    -where the liquid enters the vessel in relation to suction and liquid level.
    -location of wet return
    -suction location
    -excessive oil in the drum
    You would be surprised at the number of so-called refrigeration experts that can not properly design a suction or pump drum.
    Ken
    Aug 2005
    5,302
    Quote Originally Posted by TXiceman
    Now, now, don't be mean.
    I agree with you though. Most of the "experts" use rating tables and have no appreciation for the actual mechanics involved.
  1. gravity coil
    By nh3simman in forum Fundamentals
    Last Post: 25-10-2008, 02:09 PM
  2. Replies: 23
    Last Post: 06-06-2008, 02:27 PM
  3. Gravity Recirculated PHE
    By gwapa in forum NH3
    Last Post: 04-04-2007, 04:23 AM
  4. DX v/s Gravity
    By Hemant Anand in forum Industrial
    Last Post: 19-07-2006, 02:16 AM
  5. Gravity Deli not defrosting completely.
    By kengineering in forum Commercial
    Last Post: 26-04-2006, 11:25 AM
