    markiemark's Avatar
    markiemark Guest
    Water issues / Zanussi Fridge Freezer / ZNB 3240
    Our unit is a few years old.
    I have a water issue.
    For months now we have had water build up in the refridgerator section. It just needs to be wiped out every day but it would be good to fix it properly.
    I have heard that there may be a small hole in the interior rear which needs cleaning? I am not sure what purpose such a hole would serve.
    Thanks in advance.
    Oct 2004
    Scotland
    1,454
    Re: Water issues / Zanussi Fridge Freezer / ZNB 3240
    The purpose of this hole is to drain the water away which saves people having to mop up the water.
    Clean it out with a small pipe cleaner or use a air spray (one of them spray air cans that is used to clean keyboards) to blast the muck out.
    Chillin
    and go get a cuppa
    George Jackson's Avatar
    George Jackson Guest
    My Indesit TA5 S Fridge Freezer does exactly the same and yes we`ve been wiping the water away daily too. I`ve cleaned the drain hole and hope this will solve the problem. However, can anybody tell me why the fridge is constantly freezing de-freezing on the back panel. I`m quite sure that things aren`t touching the back panel. Seals are good, no noise and freezer is fine. Help please!
    38
    George
    The back panel is designed to freeze and defrost every cycle, and the resulting condensate is drained out and ends up in a tray on top of compressor or in a tray with a heater, to evaporate it away.
    If drain tube is blocked then ends up in the fridge cabinet and you have to mop it up. Try a long flexible something ( I use that plastic coated curtain wire ) and get it right through to the tray outside, then flush out with hot water and sanitze mixture.
    The gunge comes from dust etc., in the air and slimes up/blokes the drain.
    Here endeth the lesson in clearing fridge drains.
    magoo
    The freezing/defrosting is why they are now called 'Frost Free'.
    Aug 2009
    85
    or a larder fridge . which have been out for years . nothing to do with frost free freezers .
    Sep 2008
    Letsby Avenue
    359
    Try using a Plastic cable tie to push down the hole and "broggle"about !
  1. Whirlpool American fridge freezer - no water
    By mid-one in forum Domestic
    Last Post: 14-11-2008, 12:13 AM
  2. Replies: 4
    Last Post: 15-06-2008, 09:42 AM
  3. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  4. Zanussi - fridge is warm but freezer is cold.
    By Bob Ball in forum Trouble Shooting
    Last Post: 11-02-2007, 04:59 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
