21-11-2008, 01:01 PM #1
Water issues / Zanussi Fridge Freezer / ZNB 3240
Our unit is a few years old.
I have a water issue.
For months now we have had water build up in the refridgerator section. It just needs to be wiped out every day but it would be good to fix it properly.
I have heard that there may be a small hole in the interior rear which needs cleaning? I am not sure what purpose such a hole would serve.
Thanks in advance.
21-11-2008, 02:58 PM #2
Re: Water issues / Zanussi Fridge Freezer / ZNB 3240
Clean it out with a small pipe cleaner or use a air spray (one of them spray air cans that is used to clean keyboards) to blast the muck out.
and go get a cuppa
27-11-2009, 04:46 PM #3
My Indesit TA5 S Fridge Freezer does exactly the same and yes we`ve been wiping the water away daily too. I`ve cleaned the drain hole and hope this will solve the problem. However, can anybody tell me why the fridge is constantly freezing de-freezing on the back panel. I`m quite sure that things aren`t touching the back panel. Seals are good, no noise and freezer is fine. Help please!
27-11-2009, 10:26 PM #4
George
The back panel is designed to freeze and defrost every cycle, and the resulting condensate is drained out and ends up in a tray on top of compressor or in a tray with a heater, to evaporate it away.
If drain tube is blocked then ends up in the fridge cabinet and you have to mop it up. Try a long flexible something ( I use that plastic coated curtain wire ) and get it right through to the tray outside, then flush out with hot water and sanitze mixture.
The gunge comes from dust etc., in the air and slimes up/blokes the drain.
Here endeth the lesson in clearing fridge drains.
magoo
27-11-2009, 10:51 PM #5
The freezing/defrosting is why they are now called 'Frost Free'.
27-11-2009, 10:59 PM #6
27-11-2009, 11:41 PM #7
Try using a Plastic cable tie to push down the hole and "broggle"about !
Whirlpool American fridge freezer - no water
By mid-one in forum DomesticReplies: 2Last Post: 14-11-2008, 12:13 AM -
Zanussi Fridge Freezer not working after moving
By Becca in forum DomesticReplies: 4Last Post: 15-06-2008, 09:42 AM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Zanussi - fridge is warm but freezer is cold.
By Bob Ball in forum Trouble ShootingReplies: 2Last Post: 11-02-2007, 04:59 PM -
Building a wine cabinet
