    spongebob's Avatar
    spongebob Guest
    question. how to set prv on chill water make up line?
    how and what would you set the pressure regulating valve on the chillwater make up line?
    Apr 2001
    79
    5,071
    35
    Re: question. how to set prv on chill water make up line?
    Quote Originally Posted by spongebob View Post
    Measure the height of the loop (feet) and divide by two. This is the minimum pressure (psi) that must be maintained at the bottom of the loop.
    For example, if the height of the building/loop is 50 ft, the system needs 25 psi at the bottom when the water pressure is at its lowest (coldest water). Any less will put the top of the system in a vacuum and invite air problems.
    PRV's come factory set at 12 psi, which is sufficient for most residential systems, but the setting must be increased for higher structures.
    spongebob's Avatar
    spongebob Guest
    thanks for the info.
    Split Croatia
    57
    6,151
    36
    To correctly determine pressures in systems and to dimension expansion vessels, safety valves, filling networks and etc.... you could use this software.
  1. cold river water
    By eftimios in forum Fundamentals
    Last Post: 09-11-2008, 06:37 PM
  2. Water chiller help
    By ultralo1 in forum Trouble Shooting
    Last Post: 12-05-2007, 11:52 AM
  3. Iced suction line - Question from Rockfun
    By Brian_UK in forum Air Conditioning
    Last Post: 14-06-2006, 07:24 PM
  4. Will iron rich water attack copper & s/steel?
    By garyb in forum Trouble Shooting
    Last Post: 14-02-2006, 03:55 PM
  5. Minimal required R134a speed in suction line
    By DaBit in forum CPU Overclockers
    Last Post: 08-05-2002, 05:19 AM
