20-11-2008, 06:20 PM #1
Daikin R410A Split System- help ??
I am going to install a Daikin RXS35(f2v1b) outdoor unit.
As a super multi plus system I understand that I can connect upto 9 units from this Outdoor unit.
As I understand that the FTXS wall mounted units can correspond with this, what 9 units would you use ?
20 - 25 - 35 ?.
I have tried to specify, but am seeing a standard Kw heating and cooling range for all three indoors as the same ??.
Any advice ?.
Duc, sequere, aut de via decede - Lead, follow, or get out of the way !
20-11-2008, 07:33 PM #2
Re: Daikin R410A Split System- help ??
Check the outdoor unit model number and come back to us...
Multisync
london
23-11-2008, 08:13 PM #3
that is not a multi outoor unit mate, it is a straight split.
what is the total indoor capacity required?
Troubleshooting for Daikin Aircon CTK25FVEN
By JCTK in forum Air ConditioningReplies: 19Last Post: 05-06-2010, 07:18 PM -
Heating not working on split system what is the problem?
By airflo in forum Air ConditioningReplies: 10Last Post: 22-07-2008, 06:42 PM -
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM
