Thread: VSD for SAB202
    Quang's Avatar
    Quang Guest
    Question VSD for SAB202
    Hi everybody,
    Have any one try to install VSD on Sabroe screw-SAB202?
    What we need to pay attention of?
    What is the minimun RPM?
    Need to use constant tourque VSD?
    Many thanks for your in-put.
    Cheer!
    Feb 2008
    Norway
    446
    Re: VSD for SAB202
    I dont know what the minimum RPM is.
    A constant torque VSD is definitely needed.
    You might find some useful information here: http://www.refrigeration-engineer.co...light=stalling
    Re: VSD for SAB202
    Frgoscandia / England do a similar set with a package. Start at min hertz but have pre-lub oil pump, after timer control load comp to 100% then ramp up VSD to design 50/60 hertz and stop pre-lub oil pump.
    magoo
    Jul 2007
    Serbia
    48
    43
    Re: VSD for SAB202
    ...We have SAB202 and we have softwer "Unisab 2",work perfectly...
    Jun 2001
    N.Ireland
    1,630
    Re: VSD for SAB202
    Quote Originally Posted by Quang View Post
    Hi everybody,
    Cheer!
    Hi Quang
    if you want to make a rototune you need to start with a male driven screw, most are female. I have speed driven standard screws, from 30 to 60 hz.
    kind Regards Andy
