    Sep 2008
    Cheshire
    5
    Swaging/expanding kit
    Im looking for a decent swaging kit,
    Ive had the block and yoke type, which takes too much effort and sometimes gets stuck,
    and I've also got a tube expander, but without heating, it cracks 3/8'',1/4'' pipe,
    Any suggestions?
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: Swaging/expanding kit
    Put some oil on the screw thread of your yoke assembly.
    As for your expander, they ain't much good on the smaller pipes, especially with cheap copper. All you can do is try using it with the expander head not screwed on properly, expand it a bit and wind the head on a bit further each time until it is fully on. Without doing this, my expander will totally destroy most 3/8 pipes.
    Don't forget to de-burr the pipes properly first.
    If all else fails use a block and punch like we used to in the old days, its often quicker.
    Andy
    Aug 2004
    744
    Quote Originally Posted by Andy AC View Post
    Andy
    .......or become a coil king
    no swaging, no brazing and no purging.
    Personally I hate coils, but they do make sense for some people.
    Eggs
    Aug 2008
    44
    34
    I've always used a regular swage kit and never had any of those problems. But I'd really like to have one of these kits. I'm just to cheap.
    Tube Expander/Swager Kit
    Smart remarks come from smart people.
    Feb 2001
    phoenix,arizona
    72
    103
    Quote Originally Posted by platinumfreeze View Post
    Defininately get one of these.(I have a hydraulic one) Once you have one, you will wonder how you ever get along with it. Worth its weight in gold.
    Be Happy
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Chill'D View Post
    Any suggestions?
    I have this one for small pipes expanding and flaring. Works like charm.
    If you have hard drawn pipe you need to annealed it ( to heat at temperature more than 700°C) before expansion!
    For bigger diameter pipes, I recommend this!
    Sep 2008
    Cheshire
    5
    thanks for the replys,
    All i use is coils, but its hard to get some pipe runs in one go
    the only way ive found of swaging small pipe with the tube expanders is to heat the copper while in use.
    looks like its back to couplers
