    Aug 2008
    bolton uk
    Steam Condenser and heat pump
    We are trying to recover heat from a steam engine condenser to give a feed water temperature of 85C but a heat pump temperature of 275C. Our steam input is at 150 PSI. Does anyone know of a heatpump capable of working at these temperature ranges.
    11,025
    Re: Steam Condenser and heat pump
    I wouldn't think so with normal/usual refrigerants.
    What is your steam temperature, can you not use that directly?
    Also, interested to know why you want water at that temperature, 275°C.
    Aug 2008
    bolton uk
    We are using thermal oil at 275C to generate steam using a thermal oil steam evaporator. Obviously we want to condense the steam after it has gone through the twin screw expander down to the inlet temperature of the steam evaporator 85C and the opposite side of the heat pump would be to reheat the thermal oil to 275C
    Aug 2005
    5,302
    This sounds like an MVR system. Mechanical Vapor Re-compression. So, if the expander you use is suitable for the expansion process, the heat pump as you describe it is doing the same thing in reverse of the expander. As I see it, if you find the expander you find the compressor. More or less.
    China
    55
    52
    I can't get what he said.
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Low head pressure Versus Heat reclaim.
    By taz24 in forum Supermarket Refrigeration
    Last Post: 20-03-2008, 11:47 AM
  3. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  4. Attic Heat Pump
    By KETTLER in forum Heat Pumps
    Last Post: 23-02-2008, 11:33 PM
  5. Efficient Water-Source Condenser Design?
    By Enginerd in forum Fundamentals
    Last Post: 28-05-2007, 05:11 AM
