Thread: Icing problem
12-11-2008, 08:15 AM #1
Icing problem
hi! good day to everyone!
We had encountered on 40 tons DX here in the philippines. Total pipe length about 180 feet long (ACCU on roofdeck and AHU on 9th floor of the building).
The problem is:
1. Icing starts when the refrigerant charge riched to 44 psi,
2. What is the posible solution?
3. Piping sized = suction line 2 5/8
= liquid line 1 3/8
4OTons DX
12-11-2008, 06:11 PM #2
Re: Icing problem
What is the refrigerant and what are the sucion and discharger pressures on the compressor. What is the refrigerant pressure at the evaporator outlet?
Ken
13-11-2008, 03:00 PM #3
Re: Icing problem
superkent2009,
1.What are the condition of the evap unit?ice build up?
2.What is the evap outlet pressure?
we need that info so we can help.
regards,abet
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
A strange problem
By MuhengineeR in forum Air ConditioningReplies: 14Last Post: 27-10-2010, 05:21 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
Fujitsu auy30fuar icing problem
By seb in forum Air ConditioningReplies: 13Last Post: 22-03-2007, 09:35 PM
