Results 1 to 12 of 12
    Aug 2007
    SINGAPORE
    5
    460 volt 1 phase motor?
    I have some motors that are rated 460 volt 1 phase 60 Hz. I understand the more common voltage source is 460 volt 3 phase. So how does one obtain 460 volt 1 phase?
    Can anyone tell me more about this or direct me to some links with more information on this?
    Australia
    40
    13
    Re: 460 volt 1 phase motor?
    does it say one phase? or just 460V
    because if it's 460V then you're probably going to hook it up to 2 phases.
    Aug 2007
    SINGAPORE
    5
    It did mentioned 1 phase.
    Some of the motors are reversible.
    Also menitoned are the capacitors required.
    Australia
    40
    13
    best idea would be to get info from the manufacturer. or to look up a wiring diagram for it from google.
    what brand and model number is the fan?
    Aug 2007
    SINGAPORE
    5
    One of the motors is GE 5KCP39SGL794S.
    Others are Carrier models HC52VE463, FH1076 and HC45SL460.
    I have tried searching the net for wiring diagrams for any motors that are rated 460 volt 1 phase but cannot find any.
    Jun 2005
    California
    394
    Split Croatia
    6,151
    It is still one phase even you connect it between two phase of power supply.
    Two phase would be if you connect it like this: phase1-0-phase2.
    In three phase power supply you have line and phase voltage. Line voltage is between one phase and earthed 0 from transformer. Phase voltage is voltage obtained between any 2 phase of power supply. What you need is phase voltage of power supply and, by connecting it between any of 2 phases it doesn't mean that you have 2 phase motor.
    Direction of rotation with Permanent Split Capacitor is determined by placing condenser at one or another winding of motor, but if motor have one winding of lower resistance, than other winding is "phase shifting" winding, and only he could get his supply thru condenser, and rotation direction could not be changed electrically.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Yes, but remember that you will have two lives, instead than one live and one neutral.
    Split Croatia
    6,151
    Question Re: 460 volt 1 phase motor?
    Quote Originally Posted by NoNickName View Post
    What is the point in that? Except, that one case have 1 live and other case have 2 live conductors!?
    Jul 2006
    Romania
    43
    99
    do you mean monophasic (one phase )460vac????i did't hear about this...i work on 115 vac(monophasic),220-230 vac(monophasic and threephasic),380vac (threephasic),440vac (threephasic) and 6600vac (threephasic)...
    Maybe you have 3 phase and one neutral+ ground(erth conection)...or who know maybe you're right!
    Mihai
    Mar 2006
    Merate (LC) - Italy
    2,549
    There's a big difference. In a single live wiring, one fuse or single pole protection switch is enough. In a two lives wiring, you have to use two fuses or two single pole protection switches.
    If the wiring in the electric box doesn't have bipolar protection switches or fuses, it is UNLAWFUL to connect two live conductors.
    Split Croatia
    6,151
    Ok, I taught that you mean something different.
    For example, that it have any difference in functioning of 1 phase motor if you connect it between two phase of 460 V phase voltage, or if you connect it at 1 phase line voltage of 460 V and neutral.
  1. Compressor loading, cooling, and range of operation.
  2. 3 phase motor
    By mostafa_bostan in forum Electrical
    Last Post: 07-01-2008, 08:36 PM
  3. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 05:11 PM
  4. dual voltage fan motor
    By bill1983 in forum Electrical
    Last Post: 09-05-2007, 10:36 PM
  5. locked rotor amps (LRA)
    By vinod in forum Technical Discussions
    Last Post: 09-09-2006, 12:50 AM
Tags for this Thread
