Results 1 to 9 of 9
Thread: R-141b
    Mar 2008
    South Africa
    43
    7
    R-141b
    Hi guys
    I previously asked you guys for some help with pentane tables, thanks Brian_UK for your response.
    I have been unable to find any R123, R245fa, and so far n-pentane in South Africa. What I have found with similar properties is R141b. Has anyone had any dealings with this? It is generally used for foam-blowing from what I understand.
    What I'm looking to do is build an Organic Rankine Cycle,
    1. liquid refrigerant is pumped from atmospherics to a pressure of 10bar,
    2. it is then superheated using solar water heaters to between 120 and 200°C,
    3. after that it is passed through a turbine getting out mechanical power,
    4. from there it is condensed back to a liquid and the process starts over
    Anyone see any problems with using this fluid at the high temperature.
    Can copper piping be used?
    The pump that I'm looking to use has Viton seals, I'm a bit worried about the compatibility as well as the lubrication, what oils should I use, if any?
    The MSDS doesn't give too much info
    Mar 2008
    South Africa
    43
    7
    Re: R-141b
    Anyone got any info?
    Oct 2007
    Australia
    40
    13
    Re: R-141b
    I've got tables, and charts about R141b, but i've never had any experience using the stuff. i can send if you like
    Mar 2008
    South Africa
    43
    7
    Re: R-141b
    If you could that would be great, do you need my email?
    Oct 2007
    Australia
    40
    13
    Re: R-141b
    I'll put all the info in an email for you. pm me ur email address
    Sep 2008
    Lancs - UK
    67
    30
    Re: R-141b
    We used this years ago after R11 was finished, as a replacement to wash out refrigeration systems, from memory the boiling point was about 32C. It worked very well as well. WQE did manufacture a unit to recover and reclaim it from the system. But again this was finished under the second phase out of refrigerant and we were unable to use this anymore. Did not find any suitable alternatives after that.
    Mar 2008
    South Africa
    43
    7
    Re: R-141b
    Quote Originally Posted by camerond View Post
    Hi Camerond, not sure how to PM so I left a visitors message on your profile page. Not sure if you got it.
    Anyway my email is petriedave(at)gmail.com, would really appreciate it if you could send me that info.
    Dave
    asproegypt3's Avatar
    asproegypt3 Guest
    Re: R-141b
    I was searching for anything to re-charge my R-123a So I found Something Maybe It Will Be More Useful For Your Issue And
    otherwise it helps me too
    Here
    R-141b refrigerant
    .rizkbrothers.com/Arabic/products.php?tn=cHJvX3Byb2R1Y3Rz&for=MzE%3D&main=0&sub=0&pro=31&lan=Ar
    Mar 2010
    India
    7
    Re: R-141b
    We use R245fa in our ORC turbines being made in India. The best people to guide you are from "Honeywell".
    Yes you can use copper pipes if the pressure is not more than 10 bar.
    Mizun ORC
  1. forane 141b
    By pajohn in forum Refrigerants
    Last Post: 18-05-2006, 01:46 PM
