Thread: anybody has idea?
09-11-2008, 02:22 AM #1
anybody has idea?
hi guys .Iam a new in this forum and i need your help if there is a chance
what i need is a book or website talks about comparing between central air con and window type air con
thank you in advanced
09-11-2008, 08:02 AM #2
Re: anybody has idea?
Are you talking about a large residential complex and the pros and cons of central cooling/heating over individual units????
09-11-2008, 03:37 PM #3
to make it clear it is a villa contains 14 room 16 sqm each, and i want to make a study about the cost of installing and maintenance
09-11-2008, 06:43 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
09-11-2008, 11:35 PM #5
yes it is ok with windows but i need to prof its cheaper and less cost in maintenance
10-11-2008, 03:55 AM #6
How about 2 VRV systems?? one for eastern and western aspects of the villa. Do you have a ceiling cavities or concrete??
What are you load estimates? 2.5kw or 3.5kw in each room.. I don't have UK data.
at 3.5 you would need about 50kw total. yes? so 2 x 25kw 7 head multi split inverters or VRV's... Just remember they'll look neater but if the system goes down you loose half the building.
Who pays the heating/cooling bill? The body Corp or individual users? I don't know if thats something you have to incorporate into your design.
----Ps. don't take my advice as gospel, hopefully other more experienced techs will answer to this forum and give more advice.
_Dogma-
10-11-2008, 04:00 AM #7
window units are cheap as chips, can be changed out by any laman if they aren't hard wired... so thay would be the cheapest option i guess.. and the individual unit is easily tarriffed.
The question is... Do you want the service contract? or just the installation?Last edited by dogma; 10-11-2008 at 04:03 AM. Reason: put a lil more on the end
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Will this work or do you have a better idea?
By friesr in forum Technical DiscussionsReplies: 18Last Post: 24-06-2006, 10:18 AM -
is this even possible??
By Tycho in forum New TechnologiesReplies: 2Last Post: 05-05-2006, 10:20 PM -
new ice making idea
By ice builder in forum FundamentalsReplies: 13Last Post: 30-04-2006, 10:27 PM -
New idea for higher efficiency
By star882 in forum New TechnologiesReplies: 7Last Post: 22-02-2006, 04:22 PM
