    jess h's Avatar
    jess h Guest
    Freezer Floor Cross Sections
    Need a source to view cross sections. Researching construction of a freezer facility -10 -20
    India
    688
    Re: Freezer Floor Cross Sections
    Are you planning for floor panels or conventional flooring
    Mar 2006
    dallas, texas
    75
    108
    Soil conditions can effect the design. We did one big one with very little soil work and then one with Piers and sub slab of preformed concerete 12 inches above the ground, in the expansive Yazoo Clay areas of Miss.
    I like to use a compacted soil, then a mud slab about 3 inches thick where we bury a glycol tube bundle for underfloor temp control. Then a vapor barrier, double sided tape sealed at all joints, then several layers of insulation,(thickness may vary) then the reinforced finish slab.(thickness may vary)
    There are plenty of good variations but this has been good for us.
    The integrity of the vapor barrier and underfloor temperature stabilization are the most critical, and deserve to have the most attention.
    Remember it is the Vapor barrier and Vapor Pressure that are the critical variables in low temperature design, in floors, ceilings and wall joints.
    If you control these you could use rolled up newsparer for insulation....
    just joking, sort of.
    Bruce
    jess h's Avatar
    jess h Guest
    Bruce, we like in sand country wisconsin with a frost line of 48" site is level with excellent compaction and drainage
    jess h's Avatar
    jess h Guest
    Concrete floor with in floor glychol
    Mar 2006
    dallas, texas
    75
    108
    I will see if i have any drawings on some of the floors we have done.
    Construction in your area should not be too much of a problem i would think.
    Bruce
    Split Croatia
    57
    6,151
    36
    Here are some details in DWG,DXF,PDF and JPG format.
  1. ice cream truck freezer
    By GaryC in forum Transport
    Last Post: 06-12-2008, 02:19 AM
  2. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  3. Freezer compressor running 20 Hours/day
    By rickcw in forum Domestic
    Last Post: 08-03-2008, 11:50 PM
  4. Need help quick with walk-in freezer issues!
    By hysiderafter in forum Commercial
    Last Post: 12-12-2007, 12:57 AM
  5. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
