Results 1 to 17 of 17
Thread: head pressure
Hybrid View
03-11-2008, 11:03 AM #1
head pressure
Ola is me again, thought Id jus ask another dumb question.
In words only can you describe how to find head pressure using design condenser temperature, ambient air temp and a comparitor.
The handout i have says to:
Find design condenser temp
add 30F (17C) to the ambient air temp
read across comparitor to apporpriate refrigerant to find pressure. (but where did the 30F (17C) from? was it the condenser temp?)
03-11-2008, 11:14 AM #2
Re: head pressure
could some one also tell me if this is right:
compresor temp 55C
ambient temp 32C
R134a test pressure 13.7bar
Because this is the reason I am questioning my teachers handout.
03-11-2008, 07:39 PM #3
03-11-2008, 07:37 PM #4
03-11-2008, 09:07 PM #5
Re: head pressure
03-11-2008, 10:49 PM #6
03-11-2008, 08:58 PM #7
Re: head pressure
What this is telling you is that under ideal design conditions the condenser TD (difference between condenser air in temp and saturated condensing temp) should be about 30F/17K.
In the real world, where conditions are rarely ideal, the condenser TD can run anywhere from 20-35F/11-19.5K, depending primarily upon the heat load.Last edited by Gary; 03-11-2008 at 09:02 PM.
04-11-2008, 01:07 PM #8
Re: head pressure
hie guys ! r we saying the temperature of the air out of the condensor converted to the pressure of the refrigerant at that temperature is my head pressure ???
04-11-2008, 02:22 PM #9
Re: head pressure
04-11-2008, 02:49 PM #10
Re: head pressure
It is interesting to see old numbers thrown around for teaching purposes though. The 30° TD (F) is based on the way it used to be done. In today's market of higher energy costs this number should be about 15-20°.
In the lesson posted as an example the condensing temperature would drop with a corresponding decrease in condensing pressure.If all else fails, ask for help.
04-11-2008, 02:53 PM #11
Re: head pressure
That's true... today's higher efficiency systems use larger condenser coils resulting in lower TD's.
04-11-2008, 04:11 PM #12
Re: head pressure
Hi Bachus,
compresor temp 55C
ambient temp 32C
What is should say is if you have an air cooled condenser, that is on a system designed to work in temperate climate (e.g. UK), where the maximum temperature is not expected to rise above 32C.
You should obtain the saturated refrigerant pressure relating to 55C for R134a.
This pressure will then give the the minimum allowable pressure (AP) for the high side of a R134a system in accordance with BS EN 378.Tony
11-11-2008, 04:15 PM #13
Re: head pressure
thank you all very much, still I am confused. If the 17C is the condenser TD and the 32C is the ambient air temp, why do I need to know the design comdenser temp for to find my pressure?
11-11-2008, 06:39 PM #14
Re: head pressure
Originally Posted by Bachuss
That is one way of finding what the normal condensing pressure should be on a day where the ambient dry bulb temperature is 32C and the condenser is clean and operating as it should be. However, be warned this the condensing pressure is dependent on the condenser TD. If the condenser was selected with a different TD, the condensing pressure could be higher or lower.
It is important you recognize this is an example. Not everything you may find we have the same exact numbers.If all else fails, ask for help.
11-11-2008, 06:52 PM #15
Re: head pressure
so with these numbers I would find what pressure to pressure test at? and if so should i be adding 0.3 of my answer to my answer to stay in line with the BS EN 378 part 2 directive thingy??
11-11-2008, 07:09 PM #16
Re: head pressure
I can't comment on the referenced standards. The only thing the calculation procedure provides you is what the design, normal operating condensing pressure should be.
If you need to find the test pressure, then it is usually based off of the normal design pressure + some margin. The referenced standards should provide what the exact safety margin is, or should be.If all else fails, ask for help.
11-11-2008, 07:28 PM #17
Re: head pressure
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Refrigerated display cabinet, low head pressure
By expat in forum CommercialReplies: 10Last Post: 11-12-2007, 09:07 AM -
MV600 head pressure trip (ghost)
By andre_fridge in forum Technical DiscussionsReplies: 9Last Post: 28-01-2006, 02:16 PM -
Building a wine cabinet
