Results 1 to 17 of 17
    Mar 2007
    Egypt
    55
    54
    What are the damages if i do it ?
    Hi all
    What are the damages if i install comprossor was designed to work in -32C :-36C suction pressure in system work -42 C: -45 C ? the comprossor is Grasso screw
    Mar 2007
    Egypt
    55
    54
    Re: What are the damages if i do it ?
    Is this asking difficult or no one understand me ?
    Apr 2008
    phillippines
    125
    dolce,
    Operating a compressor beyond its specified performance capacity will only lead you to compressor trouble,broken valves.piston ,connecting rod,seized crankshaft etc.Better stick to what is specified.
    regards,
    abet
    Apr 2008
    phillippines
    125
    Dolce,
    operating the compressor beyond its performance capacity will only lead to mechanical trouble like broken valves,piston,connecting rod,seized crankshaft etc.
    regards,
    abet
    Aug 2003
    Netherlands
    49
    620
    21
    Could also be: No problem, just less or more capacity!
    Usually compressors are made for more then just one suction temperature.
    You'll have to get hold of a table from the manufacturer. This will show what refrigirants you can use and at which suction temperatures and condensation temperatures and what the capacity of the compressor will be. (Plus displacement etc.!!)
    So no straight forward answer! You can if the manual says you can! And if the system around it is designed correctly.
    Aug 2005
    5,302
    It is not a simple question to answer. You have to look at the limitations of the compressor. You can get these from the manufacturer.
    Pressure ratio should not be exceeded. This can greatly decrease the compressors life due to increased wear.
    Lower suction temperatures can greatly reduce the compressor capacity. Yes, the evaporating temperature will decrease, but the capacity will also. So, you have to balance the lower temperature with the lower capacity. Getting colder is NOT always the answer.
    Mar 2007
    Egypt
    55
    54
    many thanks for your replies
    Mar 2005
    638
    Partically depends on which series GRasso screw. The manufacturers publish the normal operating limits in their literature, so look there first. They usually have a minimum suction temperature and a maximum pressure differential pressure (not pressure ratio) across the compressor.
    Forgot to ask, is the machine in high stage service or booster service?
    What is the compressor Vi?
    What is the refrigerant?
    What type oil cooling?
    Which compressor series?
    What type evaporators?
    Even if it has the wrong Vi slide valve, it will most likely run at the new conditions, but the efficiency will drop off more.
    Good luck.
    Ken
    Mar 2007
    Egypt
    55
    54
    Quote Originally Posted by TXiceman View Post
    Good luck.
    Ken
    Dear Mr. Ken
    Greetings to you.here it's data sheet i'm sorry becaus i wrote type of comp. grasso but is'nt
    Product name / SAB 283 L
    Product Group / Screw comprossor unit
    Evaporation Temperature C -36 C
    Intermediate Temprature Saturation-9 C
    Refrigerant / R717
    Oil Type /M 300
    Oil cooling system /Refrige.
    VI Man/Auto /Auto
    Somerset
    69
    4,698
    Dolce.
    I would just like to point out that a SAB 283L
    Is manufactured by Sabroe
    and is defiantly nothing to do with Grasso!
    I will see if I can upload some tech data that should clarify your question!(shortly)
    Somerset
    69
    4,698
    Dolce.
    As there are several detailed options.
    Could you let us know what refrigerant you are using?
    Jan 2006
    Valrico, Florida
    509
    Dolce.
    Grizzly, It looks like its ammonia (R717) according to his last post.
    Somerset
    69
    4,698
    Quote Originally Posted by nh3wizard View Post
    As they say "Good point .Well presented."
    Silly me!
    O.K. What does type of comp. grasso but is'nt mean?
    I will try and upload more as I promised
    but my initial feeling is it's to low!
    Mar 2007
    Egypt
    55
    54
    Grizzly[/quote]
    I'm pleasure for your reply I mean there are mistake in my frist thread i wrote wrong type of comprossor
    Jul 2007
    Czech
    61
    373
    Sabroe SAB 283 L
    Suction pressure - Low warning+alarm -1,0 bar.
    Jan 2006
    Valrico, Florida
    509
    Silly me!
    Was just trying to help, Im not sure if it has a fixed VI or if its variable / auto.
    Jul 2007
    Czech
    61
    373
    Please watch for oil
  1. Noise induced hearing loss damages
    By Abe in forum Legal-Business-Marketing
    Last Post: 26-05-2008, 10:36 AM
