Thread: VRV outdoor unit location
03-11-2008, 10:32 AM #1
We are working on a VRV system (Myself for first time).
Wanted to know minimum clearance required between wall and outdoor unit for having proper amount of air volume flow rate through outdoor units.
Units are located on an exterior overhang and one side is wall while other three sides are open.
Vijay Kumar
Vijay Kumar
HVAC Design Engineer
BMCPL
"The more you sweat in peace less you bleed in war"
03-11-2008, 11:23 AM #2
Re: VRV outdoor unit location
Minimum clearence is 300 mm in this case. And 400 mm between 2 outdoors. This information should be in Installation Manual of VRV.
tx valve bulb location
By adam in forum Technical SpeculationsReplies: 28Last Post: 26-11-2009, 07:52 PM -
Volvo 850 port location >
By Latte in forum Air ConditioningReplies: 3Last Post: 07-08-2008, 10:08 PM -
Pressure Safety Valve Location
By lana in forum Technical SpeculationsReplies: 10Last Post: 16-05-2007, 08:10 PM -
location of capillary tube
By afeef in forum Air ConditioningReplies: 15Last Post: 10-07-2006, 09:40 AM -
Sight glass location
By Jai in forum Air ConditioningReplies: 7Last Post: 23-05-2002, 09:42 PM
