29-10-2008, 03:08 PM #1
Help needed sourcing an evaporator
Hi ive been assigned a task of designing a display case ( deli cabinet the refrigerated ones)
Im stuck on the evaporator
Was wondering if anyone knows the names of Evaporator Manufacturers that i could try.
So far ive contacted :
Heat Craft (Usa)
Koxka (Spain)
To no avail....
Below is the spesification im after
Refrigerant = 404A
Evaporating Temperature -10
Duty needed – 530 Watts
The dimensions of the evaporator must be in the region of 750 L x 350 W x 105 D approx mm
Im a total green horn when it comes to refrigeration...
29-10-2008, 04:04 PM #2
Re: Help needed sourcing an evaporator
I was in Thermofrost the other day they have shelves and shelves of the things. I expect other wholesalers will be able to help too.
For a bit of bedtime reading
Try here and turn to page 58.
This should get you on your way.
eggs
29-10-2008, 11:52 PM #3
Beehive coils in Newmarket www.beehivecoils.co.uk
30-10-2008, 09:11 AM #4
Cheers latte
Took a look at there web site - spot on!
Are there any other similar companies to that of beehive coills?
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Designing Roll Bond Evaporator
By Munzar Ata in forum FundamentalsReplies: 11Last Post: 05-08-2010, 11:31 AM -
Stainless steel evaporator needed
By glenjames in forum Technical DiscussionsReplies: 3Last Post: 14-03-2008, 02:22 PM -
Absortpion Refrigeration - Evaporator Basics
By knudo in forum FundamentalsReplies: 4Last Post: 28-08-2007, 08:03 AM -
What is the best location for a evaporator fan?
By Jasno999 in forum FundamentalsReplies: 3Last Post: 21-02-2007, 12:34 AM
