    bluemountain002's Avatar
    bluemountain002 Guest
    Choosing refrigerants between DuPont, Honeywell, and ICI
    Please help me choose the right refrigerant brand to use. I am installing several airconditioners and then chillers for our new shop. What refrigerant brand are much better - DuPont, Honeywell, or ICI, or do I have to continue using the unbranded ones from China? Does any of these brands have an advantage on the energy efficiency ratio? I do not have much experience on the refrigerant quality, your advice will be well appreciated! Thanks!
    Oct 2006
    1,843
    21
    Re: Choosing refrigerants between DuPont, Honeywell, and ICI
    Quote Originally Posted by bluemountain002 View Post
    As far as I know all the known brands produce identical refrigerants eg R134a is R134a from all the suppliers, R404a is R404a from all the suppliers.
    So use any brand and you should be OK.
    I can't speak for Chinese unbranded refrigerants but I can't see them being too disimilar.
    taz
    GreenCooling's Avatar
    GreenCooling Guest
    On the contrary, if you want to reduce your environmental impact, you need to use a low Global Warming Potential natural refrigerant like a hydrocarbon or CO2.
    Fortunately if you are in Australia there are very efficient and well made AC split systems using the hydrocarbon R290, see bensonairconditioning.com.au
    For the chillers you might also be able to use R290, or it might be better to look at a small CO2 option, and I'd be happy to put you in touch with the folks at eco2technologies.com.au who can help with this kind of advice.
    I'm in the Blue Mountains of NSW, and would be very interested in talking further about the options.
    Nov 2008
    Foshan,Guangdong,China
    22
    DuPont is good.
Tags for this Thread
