Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 401 to 450 of 596
  1. #401
    Dec 2010
    Philippines
    33
    30
    Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
    Hi guys i have a question when i can say my quench valve is defective this is a carrier microlink2
  2. #402
    Mar 2010
    luanda
    13
    hai,hope that u can help me on this.
    i have got a 69 -nt carrier transicold container on which i have changed exp valve (hermatic type) 2 times,but still the container running on a vaccum suction pressure.what would be the problem.
  3. #403
    Jan 2010
    REPUBLIC OF SOUTH AFRICA
    Techs you've now decided to run compressors with cylinder head cover open. That's nice.
  4. #404
    May 2008
    New Zealand
    35
    Hi there Kaushi, what temp are you trying to run the container at. With a frozen setpoint ( say -20.00deg C) R134A will run in a slight vacuum.
    Have you changed the filter drier?, also what is the model number (69NT.............-...)as some boxes have a suction modulation valve and the newer ones have a stepper motor
    really need more details
  5. #405
    Oct 2008
    bursa / turkey
    47
    219
    reefermechanic
  6. #406
    Mar 2009
    tanger
    30
    hi reefermechanic
    thanks for your anser ,plz send me ( smartsponge) to my email
    troytroy@live.fr
    terminal
  7. #407
    Mar 2010
    luanda
    13
    this model has a stepper valve. i am running this container at -20 st pt. the problem is container pulls down to a temp around -9to -11 and not below.stepper valve shows 100% opening.i have replaced the compressor for this unit because the old one had a piston damage and the whole unit was contaminated.i also flushed the system with R-11 before installing the new compressor.
  8. #408
    Mar 2010
    luanda
    13
    set point is -20 deg C.i have changed the filter drier. the unit has a stepper valve which shows a 100%opening on running the unit.
  9. #409
    May 2008
    New Zealand
    35
    hi there Kaushi, have you put the box thru a P6 test and listened for the stepper valve to open and close. Put a service manifold onto the box and check the suction pressure during the test. You will be able to see if the valve is opening or closing correctly. I have had a container that has had a jammed stepper valve piston and also have had a valve on another box with the valve piston removed. The box with the piston missing was because some one didnt have a spare valve head and it was motoring closed and staying there.
    The P6 test will show if the box is metering or not, does the box have a recip compressor or a scroll as the setups are very different. The scroll has extra valves in the system e.g LIV, LSV, ORV, USV
    We really need to know the model number (it will be something like 69NT40-541-001)
  10. #410
    Dec 2010
    Philippines
    33
    30
    kaushi try to check the stepper motor if the stepper have a good resistance follow the steps
    1st disconnect the connection of stepper motor going to power pack
    2nd get the resistance of (a-b) or red and green wires
    3rd get the resistance of (c-d) or white and black wires
    the good resistance if im not mistaken 72ohms
    hope you solve this
  11. #411
    Dec 2010
    Philippines
    33
    30
    and kaushi try to check if the software of controller is match up to the unit
  12. #412
    Sep 2011
    SELANGOR
    9
    HELLO ALLS,
    please help me about PrimeLine 561-018 model. during start Auto2 PTI, RM (remote monotoring) doesn`t start counting, it's stay on number 180, causes Auto2 PTI cannot not be started.
    already configurated and software back.
    any suggestion.
  13. #413
    Oct 2008
    bursa / turkey
    47
    219
    hi reefer contr,
    pls check your e-mail.
    see you
    reefer mecahnic
  14. #414
    Oct 2008
    bursa / turkey
    47
    219
    hi Kaushi,
    your problem solved??
    see you
    reefer mechanic
  15. #415
    HveeAC's Avatar
    HveeAC Guest
    Hey reefer mechanic. I have 2 mitsubishi CPE52-3BAA that I have to repair. Do you have a parts manual and maintenance manual??
  16. #416
    Oct 2008
    bursa / turkey
    47
    219
    Hi HveecAC
    check your e-mail.
    see you
    reefer mechanic
  17. #417
    HveeAC's Avatar
    HveeAC Guest
    Quote Originally Posted by reefermechanic View Post
    Hi HveecAC
    check your e-mail.
    see you
    reefer mechanic
    Thanks Reefer Mechanic!! Appreciate the help from you! Thank you for getting me that information. I will be sure to come to you for any other problems I have.
  18. #418
    Sep 2011
    SELANGOR
    9
    Talking Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
    hi reefer contr,
    see you
    reefer mecahnic
    Thank you very much. problem solve with update GMT time on datacorder. Thank you.
  19. #419
    Oct 2012
    India
    32
    Hi Every One here..
    I am New to this website. But I Highly appreciate contribution of Mr. Reefer Mechanic to this Forum and website.
    Best Wishes for you Reefermechanic !
    Regards,
    Dave
  20. #420
    Oct 2012
    India
    32
    Hi Every One here..
    Best Wishes for you Reefermechanic !!
    Regards,
    Dave
  21. #421
    Oct 2008
    bursa / turkey
    47
    219
    Quote Originally Posted by Brijeshdave View Post
    Hi Every One here..
    Regards,
    Dave
    Hi Dave,
    thanks for good wishes
    see you
    reefermechanic
  22. #422
    Oct 2008
    bursa / turkey
    47
    219
    Also please mail me its manual if you have it.
    Rgds
    hi dave,
    i m soory , i^can't share any program. BUt if yonu need manual maybe i can help you.
    see you
    reefermechanic
  23. #423
    Oct 2012
    India
    32
    hi dave,
    see you
    reefermechanic
    No worries & Thanks for your reply.
    Will surely ask for your help if needed.
    Rgds,
    Dave
  24. #424
    Mar 2010
    luanda
    13
    thanks guys, first of all soory for the delayed reply.it was actually a jammed stepper valve piston.i replaced it and now the container is fine.
  25. #425
    HveeAC's Avatar
    HveeAC Guest
    Hey Reefer Mechanic! I'm back again. I was wondering if you could email me the Daikin TR02-14 operation manual. I don't have it and I have gotten in 2 Daikins to repair. Thanks for your help.
  26. #426
    Oct 2008
    bursa / turkey
    47
    219
    Quote Originally Posted by HveeAC View Post
    Hi HveeAC
    Your unit 's model is LXE10E-A14/15? If ok check your e-mail box.
    see you
    reefermechanic
  27. #427
    May 2008
    New Zealand
    35
    hey there guys, can anyone tell me what type of oil separator is on a NT20-531-301, I have been told it is a float type. the reason I am asking this is that it seems to be jammed open and putting hot discharge gas back into the sump of the scroll comp. Can anyone tell me how the oil return solenoid is cycled or is it powered all the time? When I disconnect the oil return valve for testing the system running pressures come back to within the normal range and the box cools.
    The box has been running ok and now is struggling at -20. It failed the P10-2 test. after disconnecting the oil return valve solenoid coil I ran the test again and it passed. It isnt desirable to leave the oil return valve disconnected. also the condenser fan motor is on all the time and the discharge pressure gets as low as 650Kpa, I thought the condenser fan motor cycled or is that only in perishable mode(above 0 deg) the suction pressure seems to be ok for a while then goes rather erratic. The refrigerant level is way up in the top sightglass in the receiver which I think is not normal and stays there.
    I am looking at the TX valve at the moment and possibly the oil separator as well,
    Any help would be very much appreciated
    regards
  28. #428
    Oct 2012
    India
    32
    Quote Originally Posted by phil Landon View Post
    regards
    Hi Phil Landon,
    May be I can help you for this, “Can anyone tell me how the oil return solenoid is cycled or is it powered all the time?”
    The oil return solenoid valve in this model is normally open which allow oil to return during off cycle. Hence when the cycle is ON, ORV is normally closed by constant power supply.
    Regards,
    Dave
  29. #429
    Sep 2011
    SELANGOR
    9
    HELLO ALLS, did anybody have manual for thermoking crr40 (super reefer type) .
    i always facing problem of poor body insulation due to high ambient temp in here.
  30. #430
    Nov 2012
    Serbia
    1
    Hello everyone
    I have a problem with carrier thinline compressor overhjeating. I changed compressor, but same thing again. compressor run for some time, and then stops with AL24. Anyone can help?
  31. #431
    Oct 2008
    bursa / turkey
    47
    219
  32. #432
    Mar 2010
    Adelaide
    35
    Quote Originally Posted by dglaab View Post
    Hi guys:
    I have 4 carrier elite and thinline shipping container units rnning a holding room here. I would really like to intergrate their electronics with my plant plc so I could do things like initiate defrosts from it, and monitor them. Does anyone have any access to or ideas on either electrical schematics or interface programs for this?
    thanks
    Dan
    The software to communicate with carrier container units(DataLINE), you have to purchase from carrier container dealer, its proprietry software and comes with license key, it costs $480 here in aust, i just purchased mine last week, if you do buy it, update it to SP8.
    You cant polish a turd!
  33. #433
    Jun 2012
    India
    35
    4
    hello reefer mechanic,
    i am having prob wid stracool reefer.....st pt is -20 ret is -14.5 sup is -13.4 suc pre is -1.0 bar dis pre is 3.2 bar....***** level is ok.....check evap fans ok.....condensor is ok...........perform function test on one by one component shows error on Evap XV.......try to replace it...but bcoz of ice and rust its very hard to take out...dnt know wot to do? plz help me
  34. #434
    Mar 2010
    luanda
    13
    hey guys,
    i am having 2 carrier thinline 69-nt-511-363 conts that is showing problems
    1:-first one enters into defrost,but after comming out does not start automatically,one has to go there restart the unit.
    2:-the container is not entering into manual defrost.
    both these containers have an active al54 alarms.one of them i changed the sensor(supply)and put p5 but still alarm active.NEEDS HELP URGENTLY
  35. #435
    Oct 2008
    bursa / turkey
    47
    219
  36. #436
    Oct 2008
    bursa / turkey
    47
    219
    hi kaushi,
    reefermechanic
  37. #437
    Oct 2008
    bursa / turkey
    47
    219
    hi guys. I m here now."reefer container turkey" in Facebook..see youreefer mechanic
  38. #438
    Oct 2012
    India
    32
  39. #439
    Oct 2012
    India
    32
    Awaiting your reply. Sir,
    Regards,
    Dave
  40. #440
    Oct 2008
    bursa / turkey
    47
    219
    Regards,
    Dave
    Hi Dave
    yes, you can
    see you
    reefermechanic
  41. #441
    Feb 2013
    Portugal
    3
    Hello reefermechanic
    I'm an reefer electrician but new to this job. I have a problem on a carrier reefer, model 69nt40-541-015 wich has a ML3 controller. In proximately one month it fried 2 controllers. I had the container not working at all, replaced the controller, it worked fine, did the PTI, went on a trip and when it returned it was just like the removed controller. sometimes it works but giving alarms, other times the display and reefer are completely dead. It has 2 pins on connector KA (KA9 and KA10) that are the power supply to the controller, ( 33V betwen them) I think. Does the controller have any other power supply? and if not do you think that the transformer can have some sort of problem? by the way do you know the language of programming used in these controllers? is it ladder or FBD or is it something mor complex like C++?
  42. #442
    Oct 2008
    bursa / turkey
    47
    219
    Quote Originally Posted by hcarujo View Post
    Hi Friend
    I will help you. Pls contact me via reefermechanic@yahoo.com.
    See you
    reefermechanic
  43. #443
    Jan 2007
    NSW
    Hi Guys, I'm looking for a service manual for a MHI CPE52-* with a MMCC111 controller.
    I have looked on the internet and have started looking through this forum. I am at work at the moment and can't spend all day looking for this. If someone could give me a heads up it would be greatly appreciated.
    Dean
  44. #444
    Jan 2007
    NSW
    Hi again,
    I found some time to scan through all the pages today and I think I found what I was looking for.
    Dean
  45. #445
    Aug 2012
    Maldives
    4
    hello sir how are you, my name is jayin ihave some some douts can you help me?
  46. #446
    Aug 2012
    Maldives
    4
    Quote Originally Posted by jayink87 View Post
    i hope your assistance
  47. #447
    Aug 2012
    Maldives
    4
    sorry i ask to reefer mechanic
  48. #448
    Aug 2012
    Maldives
    4
    reefer mechanic please give your e mail id 'reefermechanic@yahoo.com' this id is not working
  49. #449
    Oct 2008
    bursa / turkey
    47
    219
    dear jayink87
    how can i help you?
    i m online now for reefermechanic@yahoo.com
    see you
    reefermechanic
  50. #450
    Feb 2013
    usa
    1
    Hello there! I have a Thermo King with Magnum-924 reefer unit. When it running for couple hours, the compressor totally frozen up. The ***** level is ok(not overcharged), fan works. Any help with this issue will be really appreciated. Thanks. Yury. There is my e-mail:gove777@hotmail.com
  1. Container Reefer Unit for Controlled Atmosphere (CA)
    By reeferman in forum New Technologies
    Last Post: 26-08-2011, 09:26 AM
  2. Replies: 12
  3. Help cutting open 40ft reefer, we now have problems
    By adrian_uk17 in forum Industrial
    Last Post: 28-11-2010, 08:11 AM
  4. Reefer container
    By stevec in forum Commercial
    Last Post: 25-01-2009, 05:30 PM
