Results 1 to 10 of 10
Thread: can you help me
26-10-2008, 12:18 PM #1
can you help me
hello! everibody,
can someone tell me the exact procedure to do a deep vac for a small comercial fridge.
thank you so much
26-10-2008, 12:54 PM #2
Re: can you help me
sidi,
Is that small commercial fridge a cascade system?
regards,abet
26-10-2008, 01:40 PM #3
Re: can you help me
yes, sorry i should have been more spesific
26-10-2008, 02:43 PM #4
Re: can you help me
Sidi.
Below I have added data about your question copied from the Yellow Jacket website, which is full of useful tips.
The web link goes to their download-able video showing how to use a vacuum pump.
http://www.yellowjacket.com/vacuumdownload.asp
27-10-2008, 02:24 PM #5
Re: can you help me
sidi,
as per expeience working on cascade system the aim is to evacuate the system up to 50 microns.you do a triple evac in 18 hours divide by 3.every 6 hours change oil of the pump to remove moisture on the oil and continue evacuating up to 50 microns.you may a 8 to 10 cfm pump.
regards,abet
27-10-2008, 08:05 PM #6
Re: can you help me
thaks very much, that was very helpful
04-11-2008, 01:28 AM #7
Re: can you help me
50 microns is how many psi?
04-11-2008, 04:27 PM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
04-11-2008, 10:56 PM #9
08-11-2008, 09:35 PM #10
Re: can you help me
I am Buying used grasso compressor seller told it has used cores i didnt get it what he meant can any one explain it? i a non technical personal can i get the cores fixed.
