23-10-2008, 05:12 PM #1
How to control ***** charging amount
I just installed a new compressor, I want to find out how do I control the amount of ***** being charged into the system. In my case, no matter how much I charge, the high end pressure never exceeds 150PSI, and low end pressure is always at around 50PSI. Am I doing something wrong or should I charge more ***** instead? Thanks.
23-10-2008, 06:05 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: How to control ***** charging amount
23-10-2008, 06:42 PM #3
If you are dealing with a system that has a reservoir after the condenser, as it sounds like you are, then you should look at the volume of the bottle and aim for about 3/4 fill. Bearing in mind of coarse that while 1kg of water occupies 1000cm3, refrigerants don't weigh the same for the same volume. Their specific gravities' may differ slightly but on the whole this shouldn't matter to you as they are often denser than water therefore heavier by volume.
Problem is, if you put too much refrigerant in the system the reservoir may not be able to contain it all if you want to pump down to work on the system.
Now to basics:
What's the refrigerant?
What's the expansion device?
What's the application?
etc...,
Dupont line size calculator also has 410a and 407c
By 128cyclist in forum Tools and CalculatorsReplies: 6Last Post: 20-08-2009, 03:45 PM -
Water in *****
By chemi-cool in forum RefrigerantsReplies: 47Last Post: 17-08-2009, 10:16 PM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
***** and memory lapse
By Tycho in forum FundamentalsReplies: 11Last Post: 30-01-2007, 11:17 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
