    budro's Avatar
    budro Guest
    Refrigerant flow rates/gas laws
    Hello all,
    I stumbled upon this forum looking for some info on refrigerant flow rates and it seems there are some on here with a good knowledge of real world theory application. If you have the time it would be much appreciated.
    I have a rather odd question but none the less here it is. I have a follow up question as well.
    How do you determine the flow of refrigerant through tubing using the following variables?
    A cap tube size .026” has been blocked off at one end and at the same end has one hole sized .011” drilled in the side for feeding refrigerant.
    A cap tube size .026 has been blocked off at one end and at the same end has two holes size .011” drilled in the sides for feeding refrigerant. The holes are opposing each other, not in series.
    The follow up: Using the same size tube and holes
    Would 1 tube with 2 holes feed the same as 2 tubes with one hole each?
    Lets say for calculating purposes that the liquid line feeding the tubing is 205 PSIG/15 degrees SC and 72 suction/ 19 degrees SH.
    I think that the flow would be the same, my partner is not convinced. He feels it is possible that as a result of the volume leaving hole 1 and the subsequent pressure drop that the flow would not be the same.
    11,024
    Re: Refrigerant flow rates/gas laws
    Welcome Budro, hope you enjoy the forum.
    Someone will ask you, soon no doubt, "what is the length of the capillary?"
    I assume that by 'feeding' the refrigerant you mean that is exiting the capillary at that point into a larger tube or chamber which is at 72#
    budro's Avatar
    budro Guest
    The cap tube is 2.75" long. I know it's not the typcal application but size restrictions required we try something unorthodox. The cap tube is being used to carry the refrgerant and the orifice is the .011" hole.
    budro's Avatar
    budro Guest
    Sorry,
    Yes you are correct about "feeding" into a chamber at 72#.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. Proposed Revision of UK Refrigerant Laws
    By Argus in forum Legal-Business-Marketing
    Last Post: 30-07-2008, 11:21 PM
  4. Refrigerant Flow Rates
    By ROSS VAN DUGTER in forum Fundamentals
    Last Post: 08-12-2007, 06:15 PM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
