Results 1 to 2 of 2
    Mar 2008
    United Kingdom
    54
    35
    Net Refrigeration Effect.
    Can someone explain, if I have a net refrigeration effect of say 67btu/lb using R22, that I plotted on a PH chart, how can I determine the size of the system from this data. EG, is it a 12000 btu/hr system. What incriments is the 67btu/lb taken as, per sec, per min, per hr?
    Aug 2005
    5,302
    Re: Net Refrigeration Effect.
    The value for Net Refrigeration Effect (NRE) is per pound (or kilogram). This is only the first step in determining the required mass flow per Ton (or kW) of cooling.
    Mas flow has the following units; mass per unit of time. Therefore the mass flow is determined on any one of the following; second, minute, or hour. Once you find the mass flow you simply multiply the mass flow by the required cooling capacity required. That would be the total mass flow for that cooling capacity.
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
  2. Evaporator TD and refrigeration effect
    By nambiandy in forum Fundamentals
    Last Post: 11-10-2008, 11:39 AM
  3. Negative Refrigeration Cooling effect
    By Kenny Pollin in forum Fundamentals
    Last Post: 26-03-2007, 03:53 PM
