    damo1206's Avatar
    damo1206 Guest
    HELP with charging
    Hi guys
    Can you please talk me through the simple steps of charging a fridge. I need to know about what pressures to check and what temps to check. Also can anyone tell me where to get a comparator from.
    eg. Just changed a compressor on a bench chiller. The chiller is on R134a but there is no tag telling you the weight of refrigerant. I dont want to keep charging the chiller until it starts to sweat. I want to learn the proper way.
    Thanks in advance.
    Damon Lee
    Northants
    290
    Re: HELP with charging
    Hi Damon
    Look at the next thread mate, it's answering the same as you are asking
    CB
    Apr 2006
    41
    1,620
    http://www.refrigtech.com/charge.html
    Same thing only for lower temps, if cap tube you go by super heat!
    Jun 2008
    usa
    55
    can any one tell me why my suction line temp goes up when i ad ***** (134a)
    I cant get a superheat
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by ray@mirage View Post
    Because your system is grossly overcharged? As you slowly remove the refrigerant, the suction line temp will drop. It will continue to drop until the excess is removed and then it will begin to rise (assuming you haven't destroyed the compressor).
    What does that mean?
  1. Liquid charging through the suction side
    By deu58 in forum Fundamentals
    Last Post: 02-07-2010, 05:23 AM
  2. 18 seer AS charging problem,best way?
    By nagzul in forum Air Conditioning
    Last Post: 01-05-2008, 07:44 AM
  3. Homemade charging tube
    By Tocoldtohold in forum Tools and Calculators
    Last Post: 02-12-2007, 02:25 AM
  4. Refrigerant charging weighing scale
    By malik55 in forum Tools and Calculators
    Last Post: 06-11-2006, 11:14 PM
  5. Charging Adaptor for BMW
    By Abe in forum Air Conditioning
    Last Post: 11-09-2002, 08:31 PM
Tags for this Thread
