15-10-2008, 09:19 AM #1
Calculation bypass buffer tank volume
see the attachment, take the sketch as example and see that we want to use a bypass buffer tank between Direct fired absorption chiller and air handling units. The circuit is self expanatory, the total load of chiller is 250 tons and also that of AHU is obviously the same. System will run on TD of 10.
Now i want to know how can i calculate the volume of buffer tank and also what are essential points to look for while designing the buffer tank(inner divider plate etc).
Can you give me volume of tank and calculation method.
To me the calculation can come out to be 127 cubic foot of tank volume i may be wrong, i need your support peopleLast edited by abbasi; 15-10-2008 at 09:36 AM. Reason: ADDED AN ATTACHMENT
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
15-10-2008, 09:44 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Calculation bypass buffer tank volume
Maybe you could found something from this document.
16-10-2008, 05:22 AM #3
this attachment deals with boilers not the chilled water. please see attachment in posted in my first place
16-10-2008, 06:19 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Buffer Tank Sizing
By deepakrbhat in forum FundamentalsReplies: 12Last Post: 12-02-2010, 09:31 AM -
Bypass buffer tank volume
By abbasi in forum Technical SpeculationsReplies: 3Last Post: 15-10-2008, 05:28 AM -
How an expansion tank works?
By Raadster in forum FundamentalsReplies: 6Last Post: 25-07-2008, 02:25 PM -
Where Do I Locate a Buffer Tank?
By Jethro Bush in forum Air ConditioningReplies: 7Last Post: 25-12-2007, 03:23 PM -
oil in tank heat load calculation
By abbasi in forum FundamentalsReplies: 7Last Post: 13-06-2005, 08:36 AM
