Thread: Bypass buffer tank volume
13-10-2008, 12:50 PM #1
see the attachment, take the sketch as example and see that we want to use a bypass buffer tank between Direct fired absorption chiller and air handling units. The circuit is self expanatory, the total load of chiller is 250 tons and also that of AHU is obviously the same. System will run on TD of 10.
Now i want to know how can i calculate the volume of buffer tank and also what are essential points to look for while designing the buffer tank(inner divider plate etc).
Can you give me volume of tank and calculation method.
To me the calculation can come out to be 127 cubic foot of tank volume i may be wrong, i need your support peopleLast edited by abbasi; 14-10-2008 at 05:30 AM. Reason: VISIBILITY
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
13-10-2008, 10:55 PM #2
Re: Bypass buffer tank volume
Sorry Abbasi but your Avatar is too annoying and distracting.
I cannot read your post because of it.
Also, small blue text is not easy to read.
Please try again and we will attempt to respond.Brian - Newton Abbot, Devon, UK
14-10-2008, 05:37 AM #3
15-10-2008, 05:28 AM #4
hey people help me
Buffer Tank Sizing
By deepakrbhat in forum FundamentalsReplies: 12Last Post: 12-02-2010, 10:31 AM -
surge tank on racks
By frozen ocean in forum Supermarket RefrigerationReplies: 14Last Post: 25-08-2009, 03:22 PM -
How an expansion tank works?
By Raadster in forum FundamentalsReplies: 6Last Post: 25-07-2008, 02:25 PM -
Where Do I Locate a Buffer Tank?
By Jethro Bush in forum Air ConditioningReplies: 7Last Post: 25-12-2007, 04:23 PM
