Thread: Glycol type
13-10-2008, 05:20 AM #1
Glycol type
please let me know how to select the glycol type for chillers and how to calculate the quantity as well as concentration of glycol
13-10-2008, 06:51 AM #2
Re: Glycol type
Can you be more specific/ What temp you what to run the chiller?
13-10-2008, 08:33 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Glycol type
Propylene glycol is environmentally frendly and and less health hazardous than ethylene glycol.
Other than that, they have simmilar characteristic in anti freezing performance.
Quantity and concentration is calculated by required freezing point and total volume of system.
It is plenty web sources for such a calculatins.
26-10-2008, 10:53 AM #4
Re: Glycol type
Hi, Ethylene glycol is usually used in non food safe applications, i.e. where a leak or spillage is not likely to come into contact with food, i.e. a bakery, meat plant etc... it is cheaper than propylene glycol, the propylene glycol is used in food critical applications, I have attached a document from DOW, this gives all the deets for "MonoEthylene Glycol". One point, you must buy "inhibited" glycol to protect the pipework/heat exchangers, there are many suppliers of this product around the world and DOW will most likely have a local representative, they will give advice freely, the document gives charts for calculating the concentration of Glycol in water and the relative freeze points. If you are testing a sample of Glycol/water solution to ascertain the concentration, you will need a hygrometer and a tall 1 litre flask, like those used by chemists, this will give you the specific gravity, when you have the specific gravity you can map it on the chart, this will ive you the solution freeze point. Remember, too much glycol will affect the performance of your chiller negatively.
If you need any help on this just ask.
26-10-2008, 02:17 PM #5
Re: Glycol type
Sorry, not able to post url's yet.
dow.com dowcal 10 and dowcal 20 are the ones I recommend, you can down load the info from their site, under products, then thermal fluids, then sleect the technical data sheet section, the above products are there in different languages. hope this does it.
26-10-2008, 02:30 PM #6
26-10-2008, 02:47 PM #7
Re: Glycol type
Thank you kindly Grizzly
26-10-2008, 03:09 PM #8
Re: Glycol type
No problem
I did not realise I was dealing with a man of the cloth (referance your avatar)
Grizzly.
27-10-2008, 11:07 AM #9
Re: Glycol type
Yes my child, every once in a while, only divine intervention will get a machine going, then they call me...lol
breaker type?
By tait71 in forum ElectricalReplies: 24Last Post: 05-09-2010, 04:39 AM -
glycol cooling system for soft dring
By faryuki in forum NH3Replies: 14Last Post: 21-04-2007, 03:44 PM -
Milk getting into glycol on chill press
By balerjoe in forum Trouble ShootingReplies: 16Last Post: 06-09-2005, 09:41 PM -
Glycol water valves
By eng_ab in forum IndustrialReplies: 2Last Post: 03-06-2005, 09:15 PM -
which glycol to use ?
By dchatta in forum RefrigerantsReplies: 4Last Post: 12-07-2004, 09:26 AM
