Results 1 to 10 of 10
Thread: Running pipes in concrete
11-10-2008, 11:02 AM #1
What's the best wat to run pipes in concrete?
We're starting to do alot of restaurant and supermarket fit outs which require running pipes through concrete before it is poured.
We normaly run them in PVC pipe, but what happens if the copper pipe comes in contact with the wet concrete, and would insulation alone be OK?Last edited by Jadeair; 11-10-2008 at 11:07 AM.
If I can make more than my wife can spend in a day, that's a good day....
11-10-2008, 11:52 AM #2
11-10-2008, 12:05 PM #3
Re: Running pipes in concrete
Jadeair
Simply put, how you access the pipes in future is a dilemma.
But basically put if copper is in direct contact with Concrete. It will rot!
The lime in the Concrete attacks the Copper.
I would assume that the insulation would be sufficient but very susceptible to liquid concrete seeping past it.
Surely what Tazz has suggested and you refer to,would be the most sensible solution.
IE, run it through a plastic pipe. which would enable future access as well as protect the pipe.
14-10-2008, 12:02 PM #4
We use the following method to run pipes underground and thru concrete slabs
...and she said "give it to me you big fridgie"
14-10-2008, 05:08 PM #5
21-10-2008, 01:01 PM #6
This used to be the norm in the UK and the consequence is often lots of leaks which are not accessible. Very few new installations now put the pipes in the floor. Try and persuade your client as to the benefits of running overhead. services
22-10-2008, 06:55 AM #7
23-10-2008, 11:51 AM #8
Thanks guys,
Sometimes there's no other way of getting pipes there when under constuction.
Most of the cabinets are small in capacity and can be run in soft drawn through pvc pipes without joins.
Wonder how long that lime would take to eat through the pipes if let unprotected?If I can make more than my wife can spend in a day, that's a good day....
09-11-2008, 05:09 PM #9
750,
Why foam the entire run? Wouldn't it be better to just foam the openings? I'm thinking of the hassle involved if you needed to replace or upsize the lines.
10-11-2008, 09:24 AM #10
I guess it harks back to some older practices when the pipes were laid in the ducts without insulation and the run was foamed, but all the major companies here run undergrounds in this manner still so I guess its just an industry standard.
When upgrading stores we NEVER saw cut near an existing trench, its easier to run a new one with a different route and a new pipe. Most of our stuff is overheads to mutidecks anyway so its just the service deli and low height cases such as islands that see undergrounds....and she said "give it to me you big fridgie"
Problems with compressor running too cold
By abrando1 in forum Trouble ShootingReplies: 8Last Post: 12-05-2009, 10:08 PM -
running the oil pump to check oil level
By Ice Queen in forum Technical DiscussionsReplies: 7Last Post: 02-08-2008, 05:23 PM -
Walkin cooler running to warm need help
By The Butcher in forum Trouble ShootingReplies: 7Last Post: 03-08-2007, 09:19 PM -
Installing pipes
By tuneee in forum FundamentalsReplies: 8Last Post: 05-06-2007, 08:21 PM -
Running Costs
By Abe in forum Air ConditioningReplies: 4Last Post: 09-04-2007, 12:58 AM
