Results 1 to 9 of 9
    Sep 2008
    india
    7
    please explain me..
    i just wonder about why LAF velocity is 90 FPM?? and in which room requires LAF?
    please explain me...
    Split Croatia
    57
    6,151
    36
    Re: please explain me..
    Quote Originally Posted by garde.anand View Post
    What means "LAF"?
    11,024
    We explain to you when you do not use initials; LAF is what??
    raghav's Avatar
    raghav Guest
    LAF means laminar air flow. In laminar air flow the velocity is 90 FPM. But i cant understand the logic behind it.if anybody knows the answer please explain me? again in which class and in what particular room requires LAF ???
    TRASH101's Avatar
    TRASH101 is offline Veteran Poster I am starting to push the Mods: of RE
    Mar 2007
    394
    I assume you are not refering to laminar extract.
    LAF is used in various applications such as clean rooms (class 100 or better usually) with specific particle control such as micro biological, some nanotech and so forth.
    The advantages of LAF over turbulant is that any particle pick up form shedding/ release is carried within the laminar stream to point of exit with little (ideally no) cross contamination to anywhere else except the laminar path.
    disadvantages are (apart from vent cost) is specifc design lab fixtures and fittings (everything must be aerodynamically designed to eliminate eddy currents as best it can) and the placement of them so as the laminar paths can be optimal.
    TRASH101's Avatar
    Mar 2007
    394
    Where did you get your 90 fpm value?
    The velocity you use depends on various factors such as filtration, anticipated particle sizes.
    Length of laminar path.
    Vertical path or horizontal path.
    Occupancy comfort levels (type of barrier clothing if any)
    raghav's Avatar
    raghav Guest
    thanks TRASH101. U have given much more information for me.. do u have any work experience in cleanroom. if u have & if u want to share any knowlege to me. u r always welcome...
    once again thanks for giving me such valuable information.....
    Oct 2010
    India
    37
    2
    I have found the following information which answers your question. I have directly copied the material from the source.
    Source: http://www.gmpua.com/CleanRoom/Design/Clean%20Room.pdf
    Why 90 fpm?
    The definition of laminar flow, 90 fpm plus or minus 20% does not exist officially. As a common industry practice, manufacturers and designers design the system at this velocity. The primary purpose is to provide adequate air at a velocity to keep airflow straight in uni-directional that can effectively dilute and carry away particles or contaminants generated within the room.
    Apr 2009
    Panacea, Florida
    87
    Laminar flow actually refers only to fluid flow (gas or liquid) in a duct. It is defined by a low Reynolds number, and is not actually the correct term for uniform cleanroom flow. To quote the ASHRAE Handbook, Applications: “Unidirectional air flow, though not exactly laminar, is characterized as air flowing in a single pass in a single direction through a cleanroom with generally parallel streamlines.” To further quote:
    “In a horizontal-flow cleanroom, the supply wall consists entirely of HEPA or ULPA filters supplying air at approximately 90 fpm or less (my emphasis) across the entire section of the room. Air then exits through the return wall at the opposite end of the room.”
  1. please any one can explain it...
    By garde.anand in forum Fundamentals
    Last Post: 11-10-2008, 10:07 AM
  2. Can anyone explain this please ?
    By fridge doctor in forum Air Conditioning
    Last Post: 07-12-2007, 06:01 PM
  3. please explain
    By bill allen in forum Technical Discussions
    Last Post: 19-10-2007, 12:23 AM
  4. Please Explain this
    By bernard in forum Supermarket Refrigeration
    Last Post: 15-09-2007, 04:22 AM
  5. Replies: 10
    Last Post: 24-07-2002, 02:30 PM
