Thread: FF fan problem can u help pease
10-10-2008, 05:29 PM #1
I don't normally do much with domestics so I am admittedly a bit rusty. If you can help me I am in your debt. I have been called to a customer with a large Bosch FF KGU36193. The problem is obvious, the freezer section fan will not operate, the solution however is not so clear.
The fan is free spinning and measures a reasonable resistance on the ohmmeter, so I am presuming it to be OK. At the plug in point I am measuring 15 volts AC.
My questions are : Does anyone have a schematic for this unit so that I can establish what voltage the fan should be supplied with. and/or.. Can anyone say whether the evap fan is likely to be 240V or 12V as it is not marked at all.
Many thanks,
Trevor
10-10-2008, 05:59 PM #2
Re: FF fan problem can u help pease
Sorry I can't help as I don't know anything about bosch, but aren't the low voltage motors DC?
Whats the point of stepping down 240v AC to 12V AC? Most of the time low voltage is used, it's for speed control, which has to be in DC volts. If I'm seeing 15V ac I'm going to guess the supply voltage is wrong.
Good luck though, I hope there's a bosch specialist here.
10-10-2008, 08:37 PM #3
hi mate in a domestic engineer 240v a/c mate
10-10-2008, 09:48 PM #4
Part number 266655 list price 27.68 uk
10-10-2008, 10:36 PM #5
Fan usually gets the 'zero" from the defrost heater.
When the fan not running, check first the defrost heater for conductivity.
Supco makes spare parts that fit almost all fridges.
14-10-2008, 08:05 AM #6
I think I will have to pass on this one because I know I will have trouble getting parts here anyway. But thanks for your replies fella's, constructive as ever.
A strange problem
By MuhengineeR in forum Air ConditioningReplies: 14Last Post: 27-10-2010, 05:21 PM -
carrier vvt problem
By declan simmonds in forum Air ConditioningReplies: 4Last Post: 28-01-2009, 02:53 PM -
Air Cooled Condenser Leakage Problem with R-404A
By RADHAKRISHNARAO in forum Technical DiscussionsReplies: 19Last Post: 30-07-2008, 12:21 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
York Chiller Excessive Purges Problem
By imranmd in forum CommercialReplies: 5Last Post: 07-03-2008, 05:13 AM
