Thread: moisture
    Mar 2008
    MEXICO
    7
    moisture
    How can I detect moisture in a regrigerant?
    Feb 2007
    2,473
    45
    Re: moisture
    The easiest would be to fit a moisture indicating sight-glass.
    Otherwise, there are various test kits on the market, like "total test".
    Mar 2007
    uk
    120
    Re: moisture
    In order for me to suspect it if no moisture sight glass is fitted one of the things i would note is that the system runs ok on start up but after while would start to indicate a blockage at the expansion device (as ice crystals form in it and bock it) then followed by extended equalisation time of the pressures, especially on cappilary systems.
    Feb 2001
    Doncaster, England
    199
    Re: moisture
    Hi Viking,
    total test is OK for systems which contain mineral oil but won't work on new systems which contain synthetic oil i.e. HFC systems.
    Carrier have now produced a NEW totaltest for R410A but it is expensive and they won't state that it will work with other HFCs
    Tony
  1. Acceptable Moisture Content
    By Pooh in forum Fundamentals
    Last Post: 28-03-2009, 12:56 AM
  2. Moisture in rack system.
    By Chunk in forum Supermarket Refrigeration
    Last Post: 18-06-2008, 08:07 PM
  3. Moisture
    By Abe in forum Trouble Shooting
    Last Post: 07-08-2007, 05:50 PM
  4. Moisture in Propane Liquid
    By Nizar in forum Refrigerants
    Last Post: 24-07-2006, 04:12 PM
  5. Moisture loss calculation
    By gregorm in forum Technical Discussions
    Last Post: 15-05-2006, 04:23 PM
