Results 1 to 9 of 9
Thread: Hotgas defrost
    Oct 2003
    5,630
    34
    Hotgas defrost
    Close pPicture of a hotgas defrost system we installed several years ago (Profroid)
    Jun 2001
    N.Ireland
    1,630
    Hi Peter,
    any drawings to go with the photo.
    Regards. Andy
    Oct 2003
    5,630
    34
    Originally posted by Andy
    Hi Peter,
    Regards. Andy
    I only found for the moment the original old drawing where I took some notices
    Oct 2003
    5,630
    34
    Another one from Tasselli, a case manufacturer from Italy with whom I worked often in the past.
    Jun 2001
    N.Ireland
    1,630
    Hi Peter
    on the Tasselli drawing is the extra coil and fan just to reduce the defrost hot gas temperature
    And on the Profroid design is the extra plate a subcooler
    Regards. Andy.
    Oct 2003
    5,630
    34
    Hi Peter
    Regards. Andy.
    Hadn't noticed your reply Andy.
    We never used the Tasselli drawing. As far as I understand the Italian language, it's a sort of subcooler for the returning condensate (when in defrosting mode) before putting it in the receiver.
    Yes, in the Profroid is a subcooler for the liquid before sending it to the evaporators.
    I installed in the first photo a small magnetic valve parallel over the big PM suction valve and did this to prevent large pressure shocks (equalise with the little one) after a defrosting cycle and to prevent massive liquid slugging. First the little one for some time and then the PM
    Jun 2003
    Georgia
    72
    21
    Hmmmm..... All I see is rubbatex water sponge insulation? Some Copper tubing.... Where's the beef?
    Oct 2003
    5,630
    34
    Hi Mark,
    did you found already some info concerning RETA?
    Mark, it's Armaflex mu 7.000 (so very expensive sponges) but in earlier posts there were also schematics.
    The more copper you should see, the more water and ice you should see.
    I will try to make some nicer pictures of it but everything is situated underneath a roof where you can't stand up.
    Oct 2003
    5,630
    34
    Originally posted by Marc O'Brien
    I can't see it working this way.
    It would seem to me rather a means to drain condensed vapour from the hotgas line into the common liquid line. If the condenser and receiver are higher than the evaporators then the hotgas pressure applied to the end of the liquid line would force a liquid column to develop back up the main liquid line toward the receiver. This would improve the quality of the liquid approaching the TEV's.
    Is S30 a liquid line pressure suppression valve?
    This schematic is used on all the Tasselli plants in Italy with cold gas defrost.
    I never used it but they sended it to me some years ago.
    We then used hot gas defrost.
    S30 is according to the index a simple SV. Purpose of it???
    Now you're saying it, I even don't see a departure on the receiver for the cold gas!?
    I can ask for some clarfication at the engineers of Tasselli.
  1. Hot gas defrost
    By adam5365 in forum Transport
    Last Post: 04-11-2007, 06:23 AM
  2. Hot Gas defrost suction pressure regulation
    By 87mustang in forum Technical Speculations
    Last Post: 05-08-2005, 07:25 AM
  3. Hot Gas vs. Electric Defrost
    By herefishy in forum Technical Discussions
    Last Post: 08-03-2005, 07:50 PM
  4. Electric Defrost
    By iceman007 in forum Trouble Shooting
    Last Post: 12-06-2004, 09:34 AM
  5. Hot gas/Cool gas defrost
    By JONAH in forum Technical Discussions
    Last Post: 10-04-2002, 12:15 PM
