Thread: daikin BRC1D52 service manual
04-10-2008, 01:40 PM #1
I installed a Daikin FBQ unit at my girlfriend's parents house a couple of months ago. Everything is working fine, but I was wondering to play with the static pressure settings a bit.
The unit is placed on the attic, from there with 2 flex tubes through the concrete into the new built-in fire place where 2 plenums are situated.
I know the BRC1D52 is factory setup with setting for medium tubes connected. I wanted to play with it a bit to lower air speed.
So if any of you guys had a link to a service manual for the BRCLast edited by majo; 04-10-2008 at 01:43 PM.
04-10-2008, 02:00 PM #2
Re: daikin BRC1D52 service manual
OK,
The BRC is the remote control.
(Used for all daikin a/c stuff)
If you give us the full model number of the indoor unit, I will see if I can dig out the manual you are after.
04-10-2008, 02:07 PM #3
yes indeed, that's the one I need.
The model nr of the indoor unit is FBQ50B
thanks
15-10-2008, 08:20 PM #4
anyone?
15-10-2008, 09:01 PM #5
You got mail.
15-10-2008, 09:56 PM #6
Just a thought, most Daikin remote controllers come with the instructions for setting them up.
Or was I just lucky on the last install?Brian - Newton Abbot, Devon, UK
16-10-2008, 07:08 PM #7
@'The Viking': thanks
@Brian_UK: yes indeed... but they threw the manuals away and I do not have a new install with a wired controller coming up the next few days
29-10-2008, 09:51 AM #8
The Viking, majo:
Can you pls forward me the document? I happen to have the same indoor unut and control, and I need to lower air speed as it is too noisy.
Ty vm.
23-11-2008, 10:01 PM #9
if you want information on it e mail daikin technical support and they will send it to you.
cservices@daikin.co.uk
Carrier 30GX Service Manual Required
By Hatchy in forum Refrigeration BooksReplies: 25Last Post: 05-11-2010, 08:58 PM -
Daikin Service Manual
By kin in forum Air ConditioningReplies: 10Last Post: 13-08-2009, 10:01 AM -
daikin service manual help
By omurcelik in forum Air ConditioningReplies: 2Last Post: 28-05-2008, 01:42 PM -
Daikin FVY453CBV1 SERVICE MANUAL
By fridgie37 in forum Air ConditioningReplies: 2Last Post: 05-02-2008, 11:40 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 10:27 PM
