Untitled
Carrier
2013
Results 1 to 9 of 9
    Mar 2008
    29
    32
    daikin BRC1D52 service manual
    I installed a Daikin FBQ unit at my girlfriend's parents house a couple of months ago. Everything is working fine, but I was wondering to play with the static pressure settings a bit.
    The unit is placed on the attic, from there with 2 flex tubes through the concrete into the new built-in fire place where 2 plenums are situated.
    I know the BRC1D52 is factory setup with setting for medium tubes connected. I wanted to play with it a bit to lower air speed.
    So if any of you guys had a link to a service manual for the BRC
    Feb 2007
    1,830
    Re: daikin BRC1D52 service manual
    OK,
    The BRC is the remote control.
    (Used for all daikin a/c stuff)
    If you give us the full model number of the indoor unit, I will see if I can dig out the manual you are after.
    Why not visit my website: www.the-viking.eu ?
    Mar 2008
    29
    32
    yes indeed, that's the one I need.
    The model nr of the indoor unit is FBQ50B
    thanks
    Mar 2008
    29
    32
    anyone?
    Feb 2007
    1,830
    You got mail.
    65
    9,413
    32
    Just a thought, most Daikin remote controllers come with the instructions for setting them up.
    Or was I just lucky on the last install?
    Brian - Torquay, Devon, UK
    I have to stop saying "how stupid can you be?" to my co-workers.
    They're starting to take it as a challenge...
    BASIC MAINTENANCE. If it doesn't move and it should then use WD40. If it moves but it shouldn't then use Duct Tape.
    Mar 2008
    29
    32
    @'The Viking': thanks
    @Brian_UK: yes indeed... but they threw the manuals away and I do not have a new install with a wired controller coming up the next few days
    Oct 2008
    Moscow
    37
    1
    The Viking, majo:
    Can you pls forward me the document? I happen to have the same indoor unut and control, and I need to lower air speed as it is too noisy.
    Ty vm.
    Nov 2007
    London
    482
    if you want information on it e mail daikin technical support and they will send it to you.
    cservices@daikin.co.uk
  1. Carrier 30GX Service Manual Required
    By Hatchy in forum Refrigeration Books
    Last Post: 05-11-2010, 08:58 PM
  2. Daikin Service Manual
    By kin in forum Air Conditioning
    Last Post: 13-08-2009, 10:01 AM
  3. daikin service manual help
    By omurcelik in forum Air Conditioning
    Last Post: 28-05-2008, 01:42 PM
  4. Daikin FVY453CBV1 SERVICE MANUAL
    By fridgie37 in forum Air Conditioning
    Last Post: 05-02-2008, 11:40 PM
  5. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 10:27 PM
