Thread: Howe Ice Maker
04-10-2008, 01:10 PM #1
Howe Ice Maker
Need advise on a Howe flake ice machine that appears to to shave more ice off on one side of the drum than the other,almost like the scraper blade assembly if out of centre? Also having a ice biuldup at bottom of drum (only one side). This is a machine I have only just started to take over the service on so I`m not aware of it maintenace history. The bearings seem ok as the gearbox drive motor is drawing the recommended current.
Anyone with a good knowledge of these machines I would like to get further information.
05-10-2008, 01:02 AM #2
Re: Howe Ice Maker
Is this the 30E type? I have ran a few of these. I have never changed the bearings, but just blew the dust off an old manual I have.
If this is the machine you have. the bearings are pressed into place and reamed .001 of an Inch (.0254 MM) over the shaft size. The manual only has one paragraph on changing the bearings.
Loose bearings would probably not effect the motor load by much unless they were very loose.
Most of my experience is with North Star, which is similar but larger. The symptoms of bearing failure in these is the same as you describe.
06-10-2008, 02:12 AM #3
Re: Howe Ice Maker
Its a 2000-RLE , I have seen a couple of machines where the chipper blade has touched and damaged the inner drum but only on one side???????????
I doubt that the shft is bent as these machines are biult like a army tank.
02-07-2010, 05:38 AM #4
Amana refrigerator/ice maker problem
By SCStewart in forum Trouble ShootingReplies: 6Last Post: 08-08-2010, 10:50 PM -
Ice Maker (Nice Ice) Faulty: Help!
By ArthurLeigh in forum CommercialReplies: 4Last Post: 25-10-2008, 10:49 AM -
Derating factor for ice maker using salty water
By Gonzalo Arias in forum NH3Replies: 1Last Post: 18-05-2007, 03:57 PM -
How come my freezer makes an ice maker like sound?
By dude in forum Technical DiscussionsReplies: 12Last Post: 06-03-2006, 08:47 PM -
Scotsman Dc33pa Ice Maker Troubleshooting
By Sean LaDart in forum Trouble ShootingReplies: 8Last Post: 13-02-2006, 08:01 PM
