    Sep 2008
    india
    7
    please any one can explain it...
    hi...
    i have one doubt in my mind that
    air washer and cooling tower works on same principle that is evaporative cooling then why does air washer cools air and cooling tower cools the water?
    please explain me....
    Dec 2001
    137
    23
    Re: please any one can explain it...
    Its all down to quantity.
    The air washer has a high qty of air to small amount of water so water all evaporates before air reaches saturation.
    Cooling tower has high qty of water to air so reaches saturation before all water has evaporated.
    Brit
    Sep 2008
    india
    7
    Fine thnks. But do air and water temps have any effect on the working of both cooling tower and air washer?
    Apr 2001
    79
    5,071
    35
    Heat transfers from whichever is warmer to whichever is cooler.
    May 2008
    Malta
    68
    67
    In this case the main factor affecting performance it is the ambient relative humidity the higher the rh the less effective cooling tower .
    Dec 2001
    137
    23
    Its all down to the air condition (temperature and humidity), the water temperature (effectively 100% humidity), the latent heat of evaporation.
    In the air wash hot air is passed 'through' a water mist and the water droplets evaporate raising the humidity while lowering the temperature of the air out.
    In the water tower the same thing is happening only the water will be at a higher temperature so you will also get some cooling due to the td between water and air.
    An adiabatic humidifier also works in a similar way.
    Sep 2008
    india
    7
    ok Thanks...
  1. Component Analysis For R134a Domestic Refrgerator
    By sbkvelocity in forum Domestic
    Last Post: 06-05-2008, 01:54 PM
  2. Can anyone explain this please ?
    By fridge doctor in forum Air Conditioning
    Last Post: 07-12-2007, 06:01 PM
  3. please explain
    By bill allen in forum Technical Discussions
    Last Post: 19-10-2007, 12:23 AM
  4. Please Explain this
    By bernard in forum Supermarket Refrigeration
    Last Post: 15-09-2007, 04:22 AM
  5. Replies: 10
    Last Post: 24-07-2002, 02:30 PM
