18-02-2004, 01:53 PM #1
Measure of conductivity in water for controlling NH3 leak
I have following problem:
I measure the conductivity of the water to regulate the drainwater of the condenser-water circulation. The conductivity becomes on ca. 1,500 µS/cm held. In addition I would like however an upper limit by 2,000 µs/cm, that have to control the water circulation on entering NH3.
Would ask:
1) the conductivity increases actually in supplement of NH3?
2) if no, what happens otherwise?
3)
if the detection is possible over the conductivity, how many NH3 (kg) must arrive into the water, until the value of 2,000 µs/cm reached (difference 500 µs/cm)?
4)
following calculation correct?
NH3-reaction with water becomes to ammonia chloride with a conductivity of 20.4 µs/cm (is the value correct?) Difference: 500 / 20.4 -> 24% solution?
I know about pH-Value-Measurements and Ammonion NH4 detection. But I want spend money by using the conductivity-measurement for both.
thanks
moeller
Olav Möller
17-12-2009, 11:57 AM #2
Re: Measure of conductivity in water for controlling NH3 leak
I was checking for a solution for the same problem in the search bar.
How did you solve the issue, Moeller?
Anyone has any idea on single conductivity measurement for both corrosion and ammonia?
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Comments on this please
By Robearbam in forum FundamentalsReplies: 8Last Post: 18-04-2005, 05:20 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
